Atlas FR Cranks, Diabolus and Evolve Bars, Atlas FR Shifting Guide
ATLAS FR CRANKS
Tired of hollow promises? Light but strong, Atlas FR cranks weigh 40g less than Shimano Saint, while maintaining equal strength and stiffness. Engineered for riders wanting a lightweight FR/DH crank. These cranks are manufactured in Canada using OPTIM-AL, an alloy 20% stronger than 7050 alloy, so no need for pedal inserts.
Whether dropping in big or vying for a spot on the podium, your prayers have been answered. Atlas FR is the new standard.
- A true FR/DH race crank – light enough for fast pedaling & strong enough for descents.
- CNC machined in our British Columbia, Canada manufacturing facility.
- Manufactured from OPTIM-AL, over 20% stronger compared to the commonly used 7050 alloy.
- Un-matched strength to weight ratio compared to other manufacturer’s FR/DH cranks.
- Thick walled, heat treated CroMo spindle.
- Bearings feature our new custom triple wiper seal to better retain grease & keep contaminants out.
- Bearings are factory filled with Phil Wood waterproof grease – tested & proven to extend bearing life.
- 6mm of chainline adjustment – ideal for chainguide compatibility.
- Removable granny ring spider for improved chainguide clearance.
DIABOLUS DH HANDLEBARS
- Part of the award winning Diabolus FR/DH line up of products.
- Ridden by Darren Berrecloth & Paul Bas, two of the best free riders on the pro scene today - you know these bars are good.
- Designed specifically for abusive DH racers & Free riders.
- Manufactured from cold drawn, seamless Air Alloy material.
- Internal taper increases strength & durability without adding weight.
EVOLVE DH RISER BARS
- A highly engineered bar at an attractive price point.
- Butted for an optimal strength to weight ratio.
- Wider construction & re-designed taper offers more width (26”) & increased stiffness.
ATLAS FR SHIFTING CHAINGUIDE
Our lightweight Atlas FR shifting chainguide brings compatibility & ease of installation to a whole new level. Designed for a wide range of frames & suspension systems, the Atlas guide is optimized to work flawlessly with most dual chainring set ups.
- Aggressive profiling on boomerang is designed to accommodate most frame styles.
- Advanced materials used in upper & lower guides offer unsurpassed impact strength & wear resistance.
- Independently adjustable bottom pulley swing arm allows for wrap positioning without crank set removal
- Floating pulley wheel tracks chain path
- Boomerang incorporates anti-rotation locking system for ISCG tab equipped frames - a Race Face industry first
- Compatible with 68/73, 83 & 100mm external BB shells only.
