Interbike 2008 - MTBR
DH, Zero, and Dig Armor
ZERO LIGHTWEIGHT ARMOUR
  • Rider Inspired Design: Design and input tested by Race Face pro rider Wayne Goss.
  • Lightweight Performance: Reduced hard shell construction drastically reduces overall weight without compromising the strength and integrity of the protection.
  • High Density Hard shell: Constructed of 85% Polypropylene (PP) / 15% Thermo Plastic Rubber (TPR), our custom moulded hard shell features a precision engineered matrix with reinforced dike system designed to absorb maximum impact and vibration across the shell.
  • Elbow / Forearm Protection: Two-piece construction allows for unrestricted articulation of the arm and greater control.
  • Knee / Shin Protection: Two-piece construction offers superior articulation and added protection in the event of unwanted ejection.
  • Open Back: Offers maximum breathability on climbs, shuttles and descents.
  • 13mm Perforated EVA Foam: Premium lightweight, closed cell foam enhances flow-through venting and moisture control and will not compress (i.e. ‘thin out’) over time.
  • Tight Weave Mesh: Increased hole-density offers maximum breathability while finer weave increases strength, durability and reduces overall weight.
  • 600D Nylon fabric: Strategic fabric placement offers superior abrasion resistance in key areas. PU gel treatment increases water repellency properties.
  • Fit Specific Strapping System: Finer weave strap secured to locking D ring offers maximum strength when stressed. Slight modifications to the angle and placement of the straps offer better fit and function. Inner straps feature soft brushed weave for next-to-skin comfort.
  • Woven ‘grab tabs’: Offer easy adjust with gloves.
  • TPR branding so you can represent.
    Colours Black/Grey/Green
    Sizes S-XL
    DIG KNEE
  • Low Profile Protection: The perfect marriage of hard shell and soft shell construction, the new RF knee design is less restrictive offering the ultimate in freedom of movement.
  • 600D Nylon Fabric: Strategic fabric placement offers superior abrasion resistance along front panel. PU gel treatment increases water repellency properties.
  • High Density Pliable shell: Constructed of 90% Low-density polyethylene (LDPE) / 10% Thermo Plastic Rubber (TPR), our custom knee is designed to absorb maximum impact yet retains flexibility.
  • 3mm Perforated Neoprene: Premium lightweight neoprene features increased hole-density to enhance flow-through venting and moisture control. Inner Wicking terry material laminated to inside for increased next-to-skin comfort.
  • Padded Side Walls: Triple density foam padding at sides, backed with velvet for rider comfort, offers increased coverage and protection.
  • Knee Stabilization Pad: Hidden stabilization pad centers the knee and minimizes slip to ensure optimal support throughout the knee’s full range of motion.
  • Fit Specific Strapping System: Finer weave strap offers maximum strength when stressed.
  • Urban-inspired allover print.
    Colours Black
    Sizes S-XL
    RALLY DH ARMOUR
  • Rider Inspired Design: Design and input tested by Race Face pro rider Wade Simmons.
  • Floating Back Panel: Stretches over the calf to secure placement, greatly increasing rider comfort while minimizing slip.
  • Knee Stabilization Pad: Centers the patella to ensure optimal armour placement.
  • 15mm Perforated EVA Foam: Premium open cell foam enhances flow-through venting and moisture control and will not compress (i.e. ‘thin out’) over time.
  • Cordura PU2 fabric: Strategic fabric placement offers superior abrasion resistance in key areas. PU gel treatment increases water repellency properties.
    Colours Black/Black/Grey, Black/Grey/Green
    Sizes S-XL
  • << Previous Next >>
    Back to the Race Face booth
    NLZ Socks:
    Shimano:
