Interbike 2008 - MTBR
Hayes Stroker Gram
The Stroker Trail and Carbon were already tremendously capable across a range of applications, but we knew we could make an even better brake for weight-obsessed cross-country racers and pedal-up/ pedal-down all-mountain types. The result is the Stroker Gram. What sets the Gram apart from all the other models in the Stroker family is the removal of non-structural material from the master cylinder (confirmed by finite element analysis), leaving behind a form that is as strong as it is sexy. We've also dressed up both the master cylinder and the caliper in titanium hardware, and thrown in our lightweight aluminum-backed pads. Sure, there are lighter brakes out there, but none match the Stroker Gram's combination of weight, power, modulation, serviceability, durability, and value. Available Rotor Sizes: 140 (rear-only), 160, 180, 203, 224 (mm)
<< Previous Next >>
Back to the Hayes, Manitou, SUN Ringle booth
Niner Bikes:
Niner :
