Interbike 2008 - MTBR
Six One
Overview
  • Freeride light 152 mm / 6" travel frame in 3 sizes with low standover
  • 135 x 12 mm rear dropouts with Maxle through hole axle for rear end stiffness
  • New lighter designed 1–1/8" forged headtube
  • Forged link arms and BB yoke, ISCG 05 and old guide mounts
  • RockShox Lyric Solo Air
  • Marzocchi TST air rear shock
  • Truvativ Stylo crank with E–13 DRS dual guide
  • Sram X9
  • Sun Jumping Flea hubs
  • DMR mag pedals and Alex welded rims
    SPECS
  • name: SIX ONE
  • frame: Hydraformed AL, 161mm of travel, 135 x 12mm maxle dropouts
  • fork: Rockshox Lyric Solo “R” Air, 20 mm dropout, 160mm of travel, 1-1/8” alloy steer tube
  • rear shock: Marzocchi TST Air shock
  • headset FSA Orbit MX-20 1-1/8”
  • crankset: Truvativ Stylo OCT hollow, 24/36, E-13 DRS Dual Ring security with red guard
  • bottom bracket: Stylo GXP
  • pedals: DMR V-12 Magnesium red
  • chain: KMC Z-9 SL Chrome CP super light chain
  • cassette: Sram PG-990, 9 speed, 11-32T
  • front derailleur: Shimano Deore 31.8
  • rear derailleur: Sram X-9, 9 speed, medium cage
  • shifters: Sram X-9 trigger, 9 speed front and rear
  • bar: Funn Fatboy, Triple butted 710x50mm, 31.8, custom graphic
  • stem: FSA Gravity Lite alloy, 31.8mm, 50mm or 70mm
  • grips: Pro Palm lock on grip
  • front brake: Hayes Stroker Trail, 8” rotor
  • rear brake: Hayes Stroker Trail, 7” rotor
  • brake levers: Hayes Stroker Trail
  • front hub: Sun Jumping Flea, 20mm axle, sealed bearing, red
  • rear hub: Sun Jumping Flea, 135 x 12mm, 9 spd, sealed bearing, red
  • rims: Alex FD-28, welded, 32 hole black
  • spokes: Stainless steel double butted, black
  • tires: Kenda Nevegal 26 x 2.35, Stick E rubber, kevlar bead,
  • saddle: WTB Rocket Comp, kevlar corners, chromoly rails
  • seatpost: FSA Gravity DH-300 double bolt, 30.9
  • sizes: S,M,L
  • colours: Red
  • << Previous Next >>
    Back to the Norco booth
    Shimano:
    Magura Marta SL Magn:
