Interbike 2008 - MTBR
Shore One
Overview
  • Hardcore freeride 179 mm / 7" travel bike for big Shore style lines
  • Available in 3 Sizes
  • RockShox 7" Totem Coil fork with 1.5" forged headtube
  • 150 x 12 Maxle through hole rear dropouts, forged yoke and link arms Hydraform main frame tubing for maximum standover and low center of gravity
  • Truvativ Hammerschmidt crank eliminates the chainguides and front derailleurs
  • Sram X9 Avid Elixir 8" rotor brakes and colour matched Sun Jumping Flea hubs
    SPECS
  • name: SHORE ONE
  • frame: Hydraformed AL, 175mm of travel, 150 x 12mm maxle dropouts
  • fork: Rockshox Totem Coil, 180mm of travel, 1.5” alloy steer tube
  • rear shock: Fox DHX-5
  • headset: FSA Orbit Extreme Pro 1.5” alloy
  • crankset: Truvativ Hammerschmidt internal double, built in guard, bb
  • bottom bracket: Truvativ Hammerschmidt
  • pedals: DMR Magnesium, steel pins, red
  • chain: KMC X-9 Gold Ti nitrate
  • cassette: Sram PG-970 DH, 9 speed, 11-26T
  • front derailleur: Truvativ Hammerschmidt
  • rear derailleur: Sram X-9, 9 speed, medium cage
  • shifters: Sram X-9 trigger, 9 speed front and rear
  • bar: Funn Fatboy triple butted 50mm rise, 31.8mm, custom graphic
  • stem: Truvativ Holzfeller 1.5 alloy, 31.8mm, 40mm / 50 mm extension
  • grips: Pro Palm lock on grip
  • front brake: Avid Elixer CR, 8” rotor
  • rear brake: Avid Elixer CR, 8” rotor
  • brake levers: Avid Elixer CR
  • front hub: Sun Jumping Flea, 20mm axle, sealed bearings
  • rear hub: Sun Jumping Flea, 150 x 12mm, 9 spd, sealed bearings,
  • rims: Sun Equilizer welded 29 mm, 32 hole
  • spokes: DT Comp. stainless black 2.0 / 1.8 / 2.0
  • tires: Kenda Nevegal 26 x 2.5, Stick E rubber
  • saddle: WTB Rocket V Comp, chromoly rail
  • seatpost: Truvativ XR double bolt, 30.9
  • sizes: S,M,L
  • colours: White
  • << Previous Next >>
    Back to the Norco booth
    Chrome:
    WTB Wolverine Race:
