Interbike 2008 - MTBR
Fluid One LT
Overview
  • All mountain 152 mm / 6" travel frame with hydraform main frame tubing, new forged link arms, chainstay clevis, light weight with low standover and available in 5 frame sizes
  • Rockshox Lyric 2 step air
  • Fox DHX Air 5.0 rear shock
  • Crank Bros direct set headset
  • Crank Bros Joplin post
  • Sram X0 Rear Derailleur and shifters
  • Sram Elixir carbon lever brakes and Industry 9 wheelset with DT rims
    SPECS
  • name: FLUID LT 1
  • frame: Hydraform main frame tubing, low standover, 137mm-158mm travel, 135 x 10mm dropout
  • fork: Rockshox Lyric 2 step, 160mm travel, 20 mm axle, 1-1/8” alloy steer tube
  • rear shock: Fox DHX-Air 5
  • headset: Crank Bros Direct Set 1-1/8”
  • crankset: Truvativ Stylo OCT, 44/32/22T
  • bottom bracket: Truvativ Stylo
  • pedals: Crank Bros Candy C
  • chain: KMC EX-9 Superlight chrome
  • cassette: Sram PG-990, 9 speed, 11-34T
  • front derailleur: Shimano XT 31.8
  • rear derailleur: Sram X-0, 9 speed, long cage
  • shifters: Sram X-0 trigger, 9 speed front and rear
  • bar: Sunline V1 Alloy, 31.8mm
  • stem: Thomson X4 alloy, 31.8mm, O deg
  • grips: Pro Palm lock on grip
  • front brake: Avid Elixer CR, 7” rotor
  • rear brake: Avid Elixer CR, 7” rotor
  • brake levers: Avid Elixer carbon
  • front hub: Industry 9, 20mm axle, sealed bearings, orange
  • rear hub: Industry 9, 135 x 10mm, 9 spd, sealed bearings, orange
  • rims: DT Swiss EX-5.10
  • spokes: Industry 9 alloy, orange
  • tires: Kenda Nevegal 26 x 2.35, kevlar
  • saddle: WTB Devo with Nicro tubular rail, synthetic leather
  • seatpost: Crank Bros. Joplin, with remote h-bar adjust
  • sizes: XS,S,M,L,XL
  • colours: Urban Brown
  • Next >>
    Back to the Norco booth
    Exustar:
    Exustar:
