M.C.R. 9 - Magic Carpet Ride
The M.C.R. 9 is built from the ground up to give you nothing short of a Magic Carpet Ride.
Featuring our proprietary Reynolds 853 tubing and custom s-bend rear seat stays and
chain stays, the M.C.R. 9 smooths out even the roughest of trails without the weight penalty
of other steel frames.
>> Our proven Niner geometry uses short chain stays and a steep head tube angle to keep
the wheelbase compact, making the bike maneuverable around even the tightest hairpins,
while the larger wheels help to increase high-speed stability, creating a fast and nimble
ride. A radically sloping top tube makes room for the family jewels and the disc-only frame
means you’ll stop on a dime. Tubing is drawn out for each frame, and external, as well as
internal, wall thicknesses have been tweaked to produce the best possible ride quality for
each frame size. Everything about this frame was thought through, including tire clearance
for fat tires and downtube clearance from pesky high fork crowns.
>> The M.C.R. 9 is the perfect go-anywhere bike that will keep you in the saddle and more
comfortable for the long haul. The superlative quality of Reynolds 853 steel tubing with
Niner-specific geometry and the stability of the 29” wheel offer a ride quality unsurpassed
in any other production hardtail frame.
The M.C.R. is offered in A&W Root Beer (in stock) and Solid Gold. (this December) (shown in special IMBA colors)
Retail Price of $799
