Racing’s in our blood. We’ve taken World Cup wins and NORBA titles and it’s a serious part of our product development and our commitment to the sport. So when we call a bike Team or Pro it’s much more than a name. It’s our name. It’s what we do.
This year’s Dakar XCR Team and XCR Pro share a new, lightweight carbon frame that makes turning race laps as easy as turning the pedals. Produced using the same state-of-the-art carbon fiber technologies as our revolutionary Xenith. Our advanced monocoque construction process assures uniform compaction and continuous fiber overlap for superior strength in an exceptionally lightweight platform. Top and down tubes are tri-ovalized for optimal stiffness with SST size-specific tubing diameters tuning that stiffness for every frame size.
Both take full advantage of our race-proven mp3 multi-link suspension – fully active with pivot placement optimized for a solid pedal platform with minimal chain growth or pedal feedback. The shock-friendly 2.63:1 leverage ratio assures the Fox rear shocks will work as intended so tires stay planted and secure whether you’re forging ahead on a climb, or stretching your lead on a descent.
Components spec is all top shelf. There’s not a reason to upgrade ever -- seriously.
Features and Benefits
- Carbon Fiber frame uses SST (size specific tubing). Each frame uses tube diameters designed specifically for that size frame. DYAD T700/M30 construction
- XCR MP³ multi-link suspension design is optimized to shed weight
- Near vertical axle path, fully-active 100mm rear wheel travel, Fox Float RP2 rear shock offers maximum ProPedal adjustability allowing riders to dial in the level of firmness desired
- Constant seatstay & bell crank length on all frame sizes assures ride characteristics are the same regardless of frame size
- Fox 32F 100RL fork offers legendary Fox precision manufacturing & industry leading stiffness-to-weight ratio with the enhanced steering precision and highly evolved damping performance that is synonymous with the Fox name. Features adjustable air pressure, rebound & low-speed compression damping, push-button lockout
- Shimano’s XTR new Shadow rear derailleur Using the New XTR Shadow rear der. featuring a low profile for improved life, quiet; will not contact chainstay, direct routing; reduces risk of snagging and stronger return spring for crisp shifting.
- New Instant Release shifting with 2-way release, composite chainring design, re-profiled titanium cassette sprockets & new 3-pc alloy carrier
- Mavic XM317 eyeleted disc rims and Shimano CenterLock hubs, 14G WTB spokes
- Easton’s carbon fiber components are the most advanced carbon bike parts on the planet, thanks to their proprietary CNT Enhanced Resin System & carbon Taperwall technology
- Easton 31.6 seat post is stiffer, stronger and will promote a better ride
- WTB Silverado Team features a smooth elongated shell, light weight and superior racer-body fit. The long narrow length allows the rider more pedaling positions and options for set up
