Interbike 2008 - MTBR
5-Spot Link
The patent pending Hex-Loc Pivot System is designed to provide the dw-link / journal bearing fusion with unsurpassed structural superiority: stronger, stiffer & smarter. The Pivot Shaft is spiral grooved to aide in the distribution of lubricating grease throughout the entire bearing system, while the hard anodized alloy surface is extremely durable and will not corrode in even the harshest enviroments. Then internally machined to accept the hex-lock link to create a solid platform for the dw-link to remain fully active even under heavy side loads.
<< Previous Next >>
Back to the Turner booth
Sette Razzo XT 10sp 29er:
Mountain Cycle:
