Interbike 2008 - MTBR
Krylion Carbon
Our Longest Lasting Road Tire.
Fast rolling smooth carbon-reinforced tread.
Excellent puncture resistance: 5 casing plies under the tread.
With rolling efficiency nearly equal to that of most top end racing tires, the Michelin Krylion Carbon road tire offers exceptional durability and superb grip on dry or wet roads. Highly resistant to microcuts, it combines reliability, durability and performance in one awesome tire.
Thicker center tread reinforced with carbon; increases mileage by over 30% over Pro Race tire.
ESC extra supple casing reinforced with bead to bead puncture protector for both flexibility and puncture resistance.
Michelin Krylion Carbon:
  • Extra Supple Casing– highly flexible, cross-ply carcass with 127 TPI (420 threads/dm²) cord density, a technology used in top-of-the-line tires that helps them achieve the highest levels of performance
  • Flexible beads (foldable tires)
  • Interwoven Bead-to-Bead Puncture Protector is a special interwoven material inserted between casing plies, protecting the entire carcass)
  • High Protect Rim System – Protective strip that protects the bead area against wear from the rim. The HPRS is used on all flexible-bead Michelin tires\
  • Lightweight skinwalls, with casing plies surrounded by a thin coat of rubber
Krylion® Carbon Color Wt. Bead
20-622 (700X20C) black / gray stripes 220g FOLDABLE
23-622 (700X23C) black / gray stripes 235g FOLDABLE
23-622 (700X23C) black / red stripes 235g FOLDABLE
23-622 (700X23C) black / yellow stripes 235g FOLDABLE
25-622 (700X25C) black / gray stripes 290g FOLDABLE
Sugg. Retail $51.99
<< Previous Next >>
Back to the Michelin booth
pHastLegs NEW:
eCycle:
