Interbike 2008 - MTBR
City
The MICHELIN CIty street tire's tread pattern makes this tire particularly well-suited to asphalt and cobblestones. The special Protek?Compound rubber mix helps ensure the tire’s integrity from the first mile to the last, thanks to antioxidant ingredients and a reinforced architecture. Protek Plus combines this special Protek Compound rubber mixture with a protective reinforcement band under the tread (Protek Shield).
Tough Protek Plus layer under the tread was designed to make punctures a thing of the past. And the tread pattern makes this tire particularly well-suited to asphalt and cement.
  • Special PROTEK COMPOUND rubber mix with antioxidant elements and a reinforced architechture that promote High mileage and excellent grip and Resistance to aging, climatic variations and pollution
  • 1mm thick PROTEK SHIELD anti-puncture reinforcement under the tread
City COLOR Wt. BEAD
35-559 (26x1.4”) black / reflective sidewall 595g RIGID
35-559 (26x1.4”) black 590g RIGID
47-559 (26X1.85”) black / reflective sidewall 795g RIGID
47-559 (26X1.85”) black 790g RIGID
28-622 (700X28C) black / reflective sidewall 595g RIGID
28-622 (700X28C) black 590g RIGID
32-622 (700X32C) black / reflective sidewall 680g RIGID
32-622 (700X32C) black 675g RIGID
37-622 (700X35C) black / reflective sidewall 680g RIGID
37-622 (700X35C) black 675g RIGID
40-622 (700X38C) black / reflective sidewall 780g RIGID
42-622 (700X40C) black / reflective sidewall 795g RIGID
42-622 (700X40C) black 790g RIGID
47-622 (700x47C) black / reflective sidewall 915g RIGID
47-622 (700x47C) black 910g RIGID
Sugg. Retail $29.99
<< Previous Next >>
Back to the Michelin booth
Aero Tech Designs:
Chrome:
