Interbike 2008 - MTBR
Cyclocross Mud2 + Jet
Michelin Cyclocross Mud2
Pure Performance for Sketchy Conditions, Excellent control in mud, slop and loose terrain, Sure-footed traction and lightweight.
It's easy to see why this is one of the most popular cyclocross tires around. Built on a supple, state of the art racing tire casing, it has the supple feel you'll want when the going gets gnarly. And the tread has been refined to precisely balance the conflicting demands of traction and efficiency - with its specially shaped and spaced knobs that help avoid the unnerving squirm associated with poorly designed knob designs. When going fast in adverse conditions, you'll be glad you’re rolling on Cyclocross Mud2 'cross tires.
Michelin Cyclocross Mud 2:
  • Proven knobby tread design with carefully spaced and shaped tread blocks, designed for impressive traction in most conditions
  • Supported multi-level tread knobs for reduced squirm and enhanced control
  • ESC extra-supple casing for flexibility, performance and lightweight
  • Silica Energy tread compound for efficiency and mud shedding
Michelin Cyclocross Jet
Speed and Traction, Engineered for dry, hardpacked trails, Balanced grip with low rolling resistance.
Whether you choose to use it front and back or mated to a more aggressive front tire, the Cyclocross Jet™ semi-slick tire is just the ticket for getting more speed out of your 'cross bike. It features the same extra supple 127 TPI casing material as we use on our professional road tires for exceptional road (or trail) feel, and our now legendary low profile Silica Energy tread with aggresssivley chiseled shoulder knobs. You get a refined balance of straightline efficiency when you just want to roll fast, and traction when you need it most - diving through corners or climbing out of ruts.
Michelin Cyclocross Jet:
  • Super fast proven semi-slick chevron tread pattern with aggressive shoulder knobs for cornering traction and stability
CycloCross Mud 2 COLOR Wt. CASING BEAD
30-622 (700X30C) black 340g 60 tpi FOLDABLE
CycloCross Jet COLOR Wt. CASING BEAD
Sugg. Retail $$55.49
<< Previous Next >>
Back to the Michelin booth
Intense 2011:
Breezer:
