Interbike 2008 - MTBR
Extreme X6 Comp
Extreme X6 Comp
  • Extreme LFP adjustable 5” to 6” travel alloy frame with sealed bearing pivot and hydroformed top tube
  • Marzocchi 55 RS 160mm travel suspension fork with 20mm thru-axle
  • Fox Van R rear shock
  • SRAM X.9 9-speed rear derailleur
  • Shimano M486 hydraulic disc brakes
    Frame Components:
  • Frame - Extreme 5/6 Frame 6061 Aluminum w/ Adjustable 5" - 6" Rear Wheel Travel
  • Sizes - 14", 16", 18", 20"
  • Frame Shock - Fox Van R
  • Colors - Speedy Spice
  • Fork - Marzocchi 55RS 160mm Travel W/ 20mm Thru Axle
  • Headset - Syncros Zero Stack Hardcore
    Drivetrain Components:
  • Crank Set - Truvativ Ruktion 2.0 24/36/Guard
  • Bottom Bracket - Truvativ Howitzer
  • Derailleur Front - Shimano Deore
  • Derailleur Rear - SRAM X.9
  • Freewheel - ShimanoHG50 9-speed 11-34
  • Chain - Shimano HG53
  • Pedals - Pivit DH Platform w/ Threaded Pins
    Control Center Components:
  • Handlebar - Syncros AM “Grunge” 40mm Rise 660 Width; 31.8 clamp
  • Stem - Syncros AM “Grunge”
  • Grips - SDG Lock-On
  • Derailleur Shifter - SRAM X.7 9-Speed
  • Saddle - SDG Bel Air I-Beam
  • Seat Post - SDG 30.9 x 350mm
  • Seat Post Clamp - Alloy QR
    Wheelset Components:
  • Hubset - Shimano M475 Rear 32h: Pivit sealed 20mm F
  • Rim - SUN Rhyno Lite 28mm w/ Eyelets
  • Spokes - Stainless Steel 14g w/ Brass Nipples
  • Tires - Kenda Nevegal 2.35; w/ Stick-E Rubber
    Brake Components:
  • Brakes - Shimano M486 Hydraulic w/180mm rotors
  • Brake Lever - Shimano M486 Hydraulic
  • << Previous Next >>
    Back to the Haro booth
    Rock Shox:
    Salsa:
