Interbike 2008 - MTBR
Extreme X6
Extreme X6
  • Extreme LFP adjustable 5” to 6” travel alloy frame with sealed bearing pivot and hydroformed top tube
  • Marzocchi 44LO 140mm travel suspension fork
  • Marzocchi Roco R coil spring rear shock with rebound adjust
  • SRAM SX-5 8-speed rear derailleur
  • Hayes MX4 mechanical disc brakes
    Frame Components:
  • Frame - Extreme 5/6 Frame 6061 Aluminum w/ Adjustable 5" - 6" Rear Wheel Travel
  • Sizes - 14", 16", 18", 20"
  • Frame Shock - Marzocchi Roco R Coil Spring w/Rebound Adj
  • Colors - Pearl White
  • Fork - Marzocchi 44LO 140mm Travel
  • Headset - Syncros Zero Stack Hardcore
    Drivetrain Components:
  • Crank Set - Truvativ Ruktion 2.0 24/36/Guard
  • Bottom Bracket - Truvativ Howitzer
  • Derailleur Front - Shimano Alivio
  • Derailleur Rear - SRAM SX-5
  • Freewheel - SRAM PG-850 8-Speed 11-32
  • Chain - KMC Z72
  • Pedals - Pivit DH Platform w/ Threaded Pins
    Control Center Components:
  • Handlebar - Syncros AM “Grunge” 40mm Rise 660 Width; 31.8 clamp
  • Stem - Syncros AM “Grunge”
  • Grips - Pivit Lock-On
  • Derailleur Shifter - SRAM SX-5 8-Speed
  • Saddle - SDG Bel Air Railed
  • Seat Post - Syncros Derived 30.9 x 350mm
  • Seat Post Clamp - Alloy QR
    Wheelset Components:
  • Hubset - Pivit Disc 32h
  • Rim - SUN Hill Rod 26mm
  • Spokes - Stainless Steel 14g w/ Brass Nipples
  • Tires - Kenda Nevegal 2.35; w/ Stick-E Rubber
    Brake Components:
  • Brakes - Hayes MX4-V7 w/ 180mm Rotors
  • Brake Lever - Tektro RS-360A
  • << Previous Next >>
    Back to the Haro booth
    Salsa:
    Contour:
