Interbike 2008 - MTBR
Extreme X7
Extreme X7
  • Extreme LFP 7” travel alloy frame with sealed bearing pivot and hydroformed top tube; 150mm rear hub spacing
  • Marzocchi 66 RCV 180mm travel suspension fork with 1.5” steer tube
  • Fox Van R rear shock
  • SRAM X.9 9-speed rear derailleur
  • Avid Juicy 5 hydraulic disc brakes
    Frame Components:
  • Frame - Extreme 7 6061 Frame; 7” Travel; 1.5” Head Tube; 150mm Rear Spacing; Hydroformed Top Tube -
  • Sizes - 16”, 18”
  • Frame Shock - Fox Van R
  • Colors - Semi Gloss Black
  • Fork - Marzocchi 66 RCV; 1.5 Steer Tube 180mm Travel
  • Headset - Syncros Hard Core 1.5 Sealed Cartridge
    Drivetrain Components:
  • Crank Set - Truvativ Ruktion 2.0 24/36/Guard
  • Bottom Bracket - Truvativ Howitzer
  • Derailleur Front - Shimano Deore
  • Derailleur Rear - SRAM X-9
  • Freewheel - SRAM PG950 9-Speed 11-34
  • Chain - SRAM PC-971
  • Pedals - Pivit DH Platform w/ Threaded Pins
    Control Center Components:
  • Handlebar - Syncros FR “Grunge” 40mm Rise 710 Width; 31.8 clamp
  • Stem - Syncros FR “Grunge”
  • Grips - SDG Lock-On
  • Derailleur Shifter - SRAM X-7 9-Speed
  • Saddle - SDG Bel Air I-Beam
  • Seat Post - SDG I-Beam 30.9 x 350mm
  • Seat Post Clamp - Alloy QR
    Wheelset Components:
  • Hubset - Pivit Disc Alloy Sealed 20mm /150mm 9 Speed Sealed Cassette; 32h QR
  • Rim - SUN Equalizer 29mm w/ Eyelets
  • Spokes - Stainless Steel 14g w/ Brass Nipples
  • Tires - Kenda Nevegal 2.5; w/ Stick-E Rubber
  • Brake Components
  • Brakes - Avid Juicy 5 Hydraulic Disc w/ 203mm Rotors
  • Brake Lever - Avid Juicy 5 Hydraulic
  • Next >>
    Back to the Haro booth
    EnduraFuel:
    Shimano Shoe Pedal Combo:
