Interbike 2008 - MTBR
Steel Reserve 1
Steel Reserve 1
Features:
  • All-new 4130 cromoly dirt- jump/urban specific frame
  • Marzocchi Dirt Jump 2 80mm fork with rebound adjust
  • 26T x 12T microdrive singlespeed gearing
  • Syncros bar and stem combo
  • Hayes MX-4 mechanical disc brake; rear only
  • Weight: 30 lbs
    Frame Components
    Frame - 4130 Double Butted Cromo W/ BMX Inspired Mid BB and Horizontal drop outs
    Sizes - 13" Short , 13" Long
    Colors - Coffee / White Fade
    Fork - Marzocchi Dirt Jumper 2 ; 20mm Thru Axle 80mm Travel
    Headset - Ritchey Drop In Internal
    Crank Set - 4130 Tubular Cromo 10 spline interface W/ e.thirteen 26t crownwheel
    Drivetrain Components
    Bottom Bracket - Mid Sealed
    Derailleur Front - N/A
    Derailleur Rear - N/A
    Freewheel - 12t Cog
    Chain - KMC 610
    Pedals - Pivit Platform w/ Replaceable Pins
    Handlebar - Syncros FR Bulk Riser Bar ; 50mm Rise 710mm Width
    Control Center Components
    Stem - Syncros FR ; 50mm Extension
    Grips - SDG Lock On
    Derailleur Shifter- N/A
    Saddle - SDG Skylite
    Seat Post - SDG I Beam Alloy Mirco Adjust
    Seat Post Clamp - Alloy Bolt on
    Hubset - Pivit Disc Alloy Singlespeed Cassette Sealed 32h Nutted R ; Pivit 20mm Sealed F
    Wheelset Components
    Rim - SUN S.O.S
    Spokes - Stainless Steel 14g
    Tires - Kenda Small Block 8 2.35F / Kiniption 2.3R
    Brake Components
    Brakes - Hayes MX4 Mechanical Disc w/ 6" Rotor Rear Only
    Brake Lever - Tektro Alloy
  • << Previous Next >>
    Back to the Haro booth
    Giro:
    Mountain Cycle:
