Interbike 2008 - MTBR
Steel Reserve 8
Steel Reserve 8
Features:
  • All-new 4130 cromoly dirt-jump/urban specific frame
  • Marzocchi Dirt Jump 2 80mm fork with rebound adjust
  • SRAM X.9 rear derailleur
  • Avid BB5 mechanical disc brakes
  • Crmo tubular 10-spline cranks
  • Weight: 33 lbs
    Frame Components
    Frame - 4130 Double Butted Cromo W/ ISCG integrated mount and vertical drop outs
    Sizes - 13" Short , 13" Long
    Colors - Pea Soup
    Fork - Marzocchi Dirt Jumper 32; 20mm Thru Axle 80mm Travel
    Headset - Ritchey Drop In Internal
    Crank Set - 4130 Tubular Cromo 10 spline interface W/ e.thirteen 36t crownwheel
    Drivetrain Components
    Bottom Bracket - Euro BB
    Derailleur Front - Syncros Chainguide
    Derailleur Rear - SRAM X.9 Composite Short Cage
    Freewheel - SRAM PG850 8-Speed 11-28
    Chain - Shimano HG-40
    Pedals - Pivit Platform w/ Replaceable Pins
    Handlebar - Syncros FR Bulk Riser Bar ; 50mm Rise 710mm Width
    Control Center Components
    Stem - Syncros FR ; 50mm Extension
    Grips - SDG Lock On
    Derailleur Shifter- SRAM X-5 Trigger Shifter; 8 Speed Right Side Only
    Saddle - SDG Skylite
    Seat Post - SDG I Beam Alloy Mirco Adjust
    Seat Post Clamp - Alloy Bolt on
    Hubset - Pivit Sealed 120t driver Disc Alloy 8/9 Speed Cassette R; 32h QR Pivit 20mm Sealed F
    Wheelset Components
    Rim - SUN S.O.S
    Spokes - Stainless Steel 14g
    Tires - Kenda Small Block 8 2.35F / Kiniption 2.3R
    Brake Components
    Brakes - Avid BBDB 5 Mechanical Disc w/ 6" Rotors
    Brake Lever - Avid FR5
  • << Previous Next >>
    Back to the Haro booth
    Easton:
    Aero Tech Designs:
