Interbike 2008 - MTBR
32 F-SERIES
32 F-SERIES
Our completely redesigned f-series is the flagship fork for xc racers in the know. New crowns, steerers and lower legs all add up to a lighter and stiffer cross country weapon. The new chassis features our 15QR lower leg option, a tool free thru axle for fast no-hassle wheel changes and incredible stiffness to weight ratio. Our race proven and improved damping gives riders velcro traction and steering precision while providing seamless transitions from compression to rebound.
New for 2009 is our 32 F-RL Remote model. The bar mounted ergonomic lever makes for quick and flawless transitions between lockout and open damping modes. Our 120 mm model is the lightest fork in its class, perfect for longer travel X/C bikes, marathon racers and light duty trail bikes. Look for the new F-Series at the front of the pack.
32 F-SERIES FAMILY FEATURES
  • NEW F-Series Remote RL system
  • NEW 15QR Thru axle system
  • NEW Lower leg
  • NEW Lighter crowns
  • NEW Lighter 1 1/8” steerer
  • NEW Optional 1.5” tapered steerer
  • Ergonomic lockout lever (RLC and RL models)
  • Post style disc brake mounting
  • Integrated disc brake cable guide (on disc only lowers)
  • NEW Updated graphics package
  • Externally adjustable lockout force (RLC model)
    MODEL: 32 F-RLC
    WEIGHT
  • F80: 3.34 lbs (1.51 kg)*
  • F100: 3.34 lbs (1.51 kg)*
  • F120: 3.47 lbs (1.57 kg)*
    TRAVEL
  • F80: 3.1 inches (80 mm)
  • F100: 3.9 inches (100 mm)
  • F120: 4.7 inches (120 mm)
    ADJUSTMENTS
  • Low speed compression
  • Lockout force adjust
  • Lever actuated lockout
  • Air spring pressure
  • Rebound
    LOWER LEG
  • standard: 9mm open drop-out w/ post style disc brake mounting
  • option: 15qr thru axle system w/ post style disc brake mounting**
  • option: 9mm open drop-out, Canti-boss, post style disc brake mounting
    STEERER
  • Standard: 1 1/8”
  • Option: 1.5” Taper (OE ONLY)
    SPRING
  • Air
    DAMPER
  • Open Bath
    FORK COLOR
  • Standard: White or Black
    MODEL: 32 F-RL REMOTE
    WEIGHT
  • F80: 3.50 lbs (1.59 kg)*
  • F100: 3.50 lbs (1.59 kg)*
  • F120: 3.63 lbs (1.65 kg)*
    TRAVEL
    ADJUSTMENTS
  • Remote lockout
  • Rebound
    LOWER LEG
    STEERER
  • Standard: 1 1/8”
    SPRING
  • Air
    DAMPER
  • Open Bath
    FORK COLOR
    MODEL: 32F-RL (OE ONLY)
    WEIGHT
  • F80: 3.29 lbs (1.49 kg)*
  • F100: 3.29 lbs (1.49 kg)*
  • F120: 3.42 lbs (1.55 kg)*
    TRAVEL
    ADJUSTMENTS
  • Rebound
    LOWER LEG
    STEERER
  • Standard: 1 1/8”
    SPRING
  • Air
    DAMPER
  • Open Bath
    FORK COLOR
    MODEL: 32 F-R
    WEIGHT
  • F80: 3.24 lbs (1.47 kg)*
  • F100: 3.24 lbs (1.47 kg)*
  • F120: 3.37 lbs (1.53 kg)*
    TRAVEL
    ADJUSTMENTS
  • Rebound
    LOWER LEG
    STEERER
  • Standard: 1 1/8”
    SPRING
  • Air
    DAMPER
  • Open Bath
    FORK COLOR
    *Fork weights shown are with standard 1 1/8” steerer at 165mm length and with standard 9mm open drop-out lower leg.
  • << Previous
    Back to the Fox Racing Shox booth
    Interbike - Trade Show Booths
