Interbike 2008 - MTBR
32 TALAS RLC 15QR
32 TALAS
THE PERFECT ALL-ROUNDER. Everything from steep climbs to your favorite downhill, the 32 TALAS® at 140-120-100mm travel settings has you covered. For 2009 we redesigned our TALAS system to offer riders more optimized spring curves for each travel setting. The user interface is now more ergonomic for fast on-the-fly travel adjustments and better protected from the elements for worry free durability. With our new 15QR thru axle system option, the incredibly stiff chassis, and our ultra-refi ned and patented RLC open bath system, the lightweight and feature packed TALAS is a sure bet for any trail condition.
32 FLOAT FAMILY FEATURES
  • NEW TALAS III system
  • NEW 15QR Thru axle system
  • NEW Lower leg
  • NEW Lighter crowns
  • NEW Lighter 1 1/8” steerer
  • NEW Optional 1.5” tapered steerer
  • Ergonomic lockout lever (RLC and RL models)
  • Post style disc brake mounting
  • Integrated disc brake cable guide
  • NEW Updated graphics package
  • Externally adjustable lockout force (RLC model)
    MODEL: 32 TALAS RLC
    WEIGHT: 3.90 lbs (1.76 kg)*
    TRAVEL: 5.5 inches (140 mm)
    TALAS 140+120+100mm
    ADJUSTMENTS
  • Low speed compression
  • Lockout force adjust
  • Lever actuated lockout
  • Travel - TALAS travel adjust 140+120+100
  • Air spring pressure
  • Rebound
    LOWER LEG
  • standard: 9mm open drop-out w/ post style disc brake mounting
  • option: 15qr thru axle system w/ post style disc brake mounting**
    STEERER
  • Standard: 1 1/8”
  • Option: 1.5” Taper (OE ONLY)
    SPRING
  • Air
    DAMPER
  • Open Bath
    FORK COLOR
  • Standard: Titanium
    MODEL: 32 TALAS RL (OE ONLY)
    WEIGHT: 3.84 lbs (1.74 kg)*
    TALAS 140+120+100mm
    ADJUSTMENTS
  • Travel - TALAS travel adjust 140•120•100
  • Rebound
    LOWER LEG
    STEERER
  • Standard: 1 1/8”
    SPRING
  • Air
    DAMPER
  • Open Bath
    FORK COLOR
    MODEL: 32 TALAS R
    WEIGHT: 3.79 lbs (1.72 kg)*
    TALAS 140+120+100mm
    ADJUSTMENTS
  • Rebound
    LOWER LEG
    STEERER
  • Standard: 1 1/8”
    SPRING
  • Air
    DAMPER
  • Open Bath
    FORK COLOR
    *Fork weights shown are with standard 1 1/8” steerer at 165mm length and with standard 9mm open drop-out lower leg.
  • << Previous Next >>
    Back to the Fox Racing Shox booth
    Chrome:
    Intense 2011:
