Interbike 2008 - MTBR
36 TALAS RC2 detail
36 TALAS
THE 36 TALAS® IS THE ULTIMATE ALL MOUNTAIN SHREDDER. Six inches? Five? Four? 4X? Big air? Switchbacks? Regardless of where or how you are riding, the 36® TALAS® is ready to go. For ’09 we improved our TALAS system to provide more optimized spring curves for each travel setting. The 3 position TALAS lever now has a more ergonomic design for quick on-the-fly (160-130-100mm) travel adjustments and is better protected from the elements for worry free durability. For those who like choices the 36 TALAS is now available with 1.5, 1 1/8 or 1.5 tapered steerers. The 20QR tool-free thru axle system makes tire changes quick and effi cient while enormous 36mm stanchions combined with the stepped 20mm axle offer unprecedented rigidity and steering precision. The improved spring curves and fully adjustable high and low speed compression and rebound damping devour whatever terrain is thrown its way. The 36 TALAS is ready, are you?
36 TALAS FAMILY FEATURES
  • NEW TALAS III
  • 20QR Thru axle system
  • NEW Improved damper dystem
  • NEW Lighter crowns
  • NEW Lighter steerers - 1 1/8?, 1.5” (OE ONLY) and 1.5” tapered (OE ONLY)
  • Post style disc brake mounting
  • Integrated disc brake cable guide
  • NEW updated graphics package
    MODEL: 36 TALAS RC2
    WEIGHT: 5.08 lbs (2.30 kg)*
    TRAVEL: 6.3 inches (160 mm)
    TALAS 160+130+100 mm
    EXTERNAL ADJUSTMENTS
  • Low speed compression
  • High speed compression
  • Travel - TALAS travel adjust 160+130+100 mm
  • Air spring pressure
  • Rebound
    INTERNAL ADJUSTMENTS
  • Hydraulic bottom-out resistance in damper
    LOWER LEG
  • 20QR thru axle system w/ Post style disc brake mounting
    STEERER
  • Standard: 1 1/8”
  • Option: 1.5” (OE ONLY)
  • Option: 1.5” Taper (OE ONLY)
    SPRING
  • Air
    DAMPER
  • FIT
    FORK COLOR
  • Standard: Titanium
    MODEL: 36 TALAS R
    WEIGHT: 4.69 lbs (2.12 kg)*
  • Rebound
    LOWER LEG
    STEERER
  • Standard: 1 1/8”
    SPRING
  • Air
    DAMPER
  • FIT
    FORK COLOR
    *Fork weights shown are with standard 1 1/8” steerer at 165mm length. (see quick guide for all 36 model weight information)
    *Close-up of new compression knobs.
  • << Previous Next >>
    Back to the Fox Racing Shox booth
    DeVinci:
    Salsa:
