36 TALAS
THE 36 TALAS® IS THE ULTIMATE ALL MOUNTAIN SHREDDER. Six inches? Five? Four? 4X? Big air? Switchbacks? Regardless of where or how you are riding, the 36® TALAS® is ready to go. For ’09 we improved our TALAS system to provide more optimized spring curves for each travel setting. The 3 position TALAS lever now has a more ergonomic design for quick on-the-fly (160-130-100mm) travel adjustments and is better protected from the elements for worry free durability. For those who like choices the 36 TALAS is now available with 1.5, 1 1/8 or 1.5 tapered steerers. The 20QR tool-free thru axle system makes tire changes quick and effi cient while enormous 36mm stanchions combined with the stepped 20mm axle offer unprecedented rigidity and steering precision. The improved spring curves and fully adjustable high and low speed compression and rebound damping devour whatever terrain is thrown its way. The 36 TALAS is ready, are you?
36 TALAS FAMILY FEATURES
NEW TALAS III
20QR Thru axle system
NEW Improved damper dystem
NEW Lighter crowns
NEW Lighter steerers - 1 1/8?, 1.5” (OE ONLY) and 1.5” tapered (OE ONLY)
Post style disc brake mounting
Integrated disc brake cable guide
NEW updated graphics package
MODEL: 36 TALAS RC2
WEIGHT: 5.08 lbs (2.30 kg)*
TRAVEL: 6.3 inches (160 mm)
TALAS 160+130+100 mm
EXTERNAL ADJUSTMENTS
Low speed compression
High speed compression
Travel - TALAS travel adjust 160+130+100 mm
Air spring pressure
Rebound
INTERNAL ADJUSTMENTS
Hydraulic bottom-out resistance in damper
LOWER LEG
20QR thru axle system w/
STEERER
Standard: 1 1/8”
Option: 1.5” (OE ONLY)
Option: 1.5” Taper (OE ONLY)
SPRING
Air
DAMPER
FIT
FORK COLOR
Standard: Titanium
MODEL: 36 TALAS R
WEIGHT: 4.69 lbs (2.12 kg)*
Air spring pressure
Rebound
LOWER LEG
STEERER
Standard: 1 1/8”
SPRING
Air
DAMPER
FIT
FORK COLOR
Standard: Titanium
*Fork weights shown are with standard 1 1/8” steerer at 165mm length.
(see quick guide for all 36 model weight information)
