Interbike 2008 - MTBR
40 RC2
THE 40
DOWNHILL RACERS ON FOX 40’S ARE THE ENVY OF THE FIELD. For 2009 we’ve taken what we learned from countless test sessions and the world’s harshest Downhill tracks and applied our knowledge to again improving our world-class RC2 Damper. The 40® also receives a direct mount stem upper crown in a lightweight optimized package for maximum grip and weight savings. The 40’s full 8-inches of travel, separate externally adjustable high and low speed compression damping circuits in the patentpending closed RC2 FIT cartridge, titanium coil spring, massive 40 mm stanchions, and sub-7 lb weight, make the 40 the defi nitive light-heavyweight champion of the world.
40 FAMILY FEATURES
  • 20QR Thru axle system
  • NEW Improved damper system
  • NEW Lighter crowns
  • NEW Lighter steerers - 1 1/8?, 1.5” and 1.5” tapered
  • Post style disc brake mounting
  • Integrated disc brake cable guide
  • NEW Updated graphics package
    MODEL: 40 RC2
    WEIGHT: 6.83 lbs (3.09 kg)*
    TRAVEL: 8 inches (203 mm)
    EXTERNAL ADJUSTMENTS
  • Low speed compression
  • High speed compression
  • Coil spring preload
  • Rebound
    INTERNAL ADJUSTMENTS
  • Travel is internally adjustable down to 6 inches in half inch increments
  • Hydraulic bottom-out in damper
    LOWER LEG
  • International Standard disc brake mounting
    STEERER
  • 1 1/8”
    SPRING
  • Titanium
    DAMPER
  • FIT
    FORK COLOR
  • Standard: White
    NEW INTEGRATED-STEM UPPER CROWN
  • Covers wide total stack height range of 105-167mm.
    *Fork weights shown are with standard 1 1/8” steerer at 165mm length. (see quick guide for all 36 model weight information)
  • << Previous Next >>
    Back to the Fox Racing Shox booth
    WTB Wolverine Race:
    Niner Bikes:
