Interbike 2008 - MTBR
DHX Air
DHX AIR
For 2009 we’ve redesigned the ProPedal® adjustment lever to have better ergonomics and improved the actuation mechanism so riders can more easily choose their ProPedal setting with a quick flick of the new 2 position 90 degree lever. The eyelet is redesigned for improved packaging and air valve access. The DHX Air is the complete package, with it’s patent-pending, position-sensitive Boost Valve®; adjustable bottom-out resistance; adjustable ProPedal; refined click-by-click linear external rebound adjustment and large volume air spring offering incredible small thru big-hit performance, in any terrain and any style of riding, in an incredibly lightweight shock.
DHX AIR FAMILY FEATURES
  • NEW 2 position ProPedal lever – light to firm in a 90 degree sweep (5.0 and 4.0 models only)
  • Critical decoupling of bottom-out resistance and ProPedal adjustment
  • Independent adjustable bottom-out resistance with common hex tool (5.0 only)
  • Adjustable velocity sensitive shimmed rebound control with linear range
  • Adjustable tuning range via Schraeder (Adjusts ProPedal & bottom out range (Min & Max))
  • Shim controlled compression damping to prevent excessive wallow or dive effect
  • Precision sized bushing to eliminate break in and increase durability
    MODEL: 5.0
    WEIGHT
    .97 lbs / 443 g
    (8.5” x 2.5” No reducers)
    ADJUSTMENTS
  • Bottom-out resistance
  • NEW ProPedal 2-position lever
  • Air spring pressure
  • Adjustable tuning range via schraeder
  • Rebound adjust
    LENGTHS
    7.5 x 2.0, 7.875 x 2.0, 7.875 x 2.25, 8.5 x 2.5, 8.75 x 2.5, 9.5 x 3.0
    MODEL: 4.0 (OE ONLY)
    WEIGHT
    .94 lbs / 429 g
    ADJUSTMENTS
  • Rebound adjust
    LENGTHS
    MODEL: 3.0 (OE ONLY)
    WEIGHT
    .92 lbs / 420 g
    ADJUSTMENTS
  • Rebound adjust
    LENGTHS
  • << Previous Next >>
    Back to the Fox Racing Shox booth
    Intense 2011:
    Giro:
