FLOAT RP23
For 2009 we improved the damping by increasing mid-stroke compression damping support and improving efficiency of the transition from rebound to compression. We also significantly broadened the rebound adjuster range. Our proprietary ProPedal® system provides pedaling thresholds with flatter compression curves for rider efficiency and maximum traction.
The flagship RP23 offers incredible ride performance with its 3-position tuning range adjuster and 2-position adjustable ProPedal lever allowing riders to quickly shift from light to firm ProPedal.
FLOAT FAMILY FEATURES
Angled air valve position for easier access
ProPedal tune – Pedaling efficiency and maximum square edge performance
Positive stops for RP23 and RP2 ProPedal lever
High volume standard air sleeve – Lower air spring compression ratio
Lightweight chassis
Dual Overhead Cam – Places damping adjustments in one easy to reach location (RP23 and RP2 only)
Speed sensitive shimmed rebound control with linear adjustments and wide range
MODEL: RP23
WEIGHT
.47 lbs / 213 g
(6.50” x 1.50” No reducers)
ADJUSTMENTS
Tuning range adjuster with 3 ProPedal positions (Patent Pending)
DOHC ProPedal with 2 positions
Rebound adjust
LENGTHS
5.5 x 1.0, 6.0 x 1.25, 6.5 x 1.5, 7.5 x 2.0, 7.875 x 2.0, 7.875 x 2.25
MODEL: RP2 (OE ONLY)
WEIGHT
.45 lbs / 205 g
ADJUSTMENTS
Rebound adjust
LENGTHS
MODEL: R (OE ONLY)
WEIGHT
.44 lbs / 200 g
ADJUSTMENTS
Rebound adjust
LENGTHS
