Interbike 2008 - MTBR
World Champion Limited Edition 40 and DHX RC4
40 RC2 World Champion
The World Champion Limited Edition 40 RC2 has been tuned and tweaked throughout the season to perform at the highest World Cup level of competition, making it perfect for the aggressive rider with highly honed skills.
Available November 2008
Only 200 individually numbered units will be produced.
SPECIFICATIONS
WEIGHT: 6.83 lbs (3.09 kg)
TRAVEL: 8 inches (203 mm)
EXTERNAL ADJUSTMENTS
  • Low speed compression?-- High speed compression
  • Coil spring preload?-- Rebound
    INTERNAL ADJUSTMENTS
  • Travel is internally adjustable down? to 6 inches in half inch increments?-- Hydraulic bottom-out in damper?-- Spring Rate
    LOWER LEG
    International Standard disc brake mounting
    STEERER
    11/8"
    SPRING
    Titanium Spring
    DAMPER
    FIT
    FORK COLOR
    White
    DXH RC4 World Champion
    This is an all new shock from the ground up. External adjustments for velocity sensitive damping and position sensitive ending stroke control act independently of one another allowing the rider to dial in the perfect balance of small bump compliance/traction, dynamic control, and big hit absorption. The World Champion version has been tuned and tweaked throughout the season to perform at the highest World Cup level of competition to give the aggressive rider the extra edge for winning performance.
    Available November 2008?Only 200 individually numbered units will be produced.
    SPECIFICATIONS
    WEIGHT
    .99 lbs. (447 g)?9.5î x 3î No reducers or spring
    ADJUSTMENTS
  • Externally Adjustable Velocity Sensitive Damping (DSC)
  • High Speed Compression
  • Low Speed Compression
  • Bottom Out Force Adjust (via Schrader Valve) -- Bottom Out Progressiveness
  • Rebound adjust
  • Coil Spring Preload
  • LENGTH 9.5x3.0
  • Next >>
    Back to the Fox Racing Shox booth
    Blackburn:
    Crank Brothers:
