Interbike 2008 - MTBR
Canaan Team
2009 Mongoose Canaan Team Mountain Bike
Mongoose lightened the Canaan up by 140 grams and made it stronger for 2009 thanks to double butted, shot-peened Xtrolite tubing. If you are an endurance rider/racer, the Canaan needs to be in your quiver of available bikes. 100mm of travel front and rear makes this bike comfy for the long hauls…like 24 hours long.
FEATURES
  • FRAME: New Mongoose Xtrolite-G6 Double Butted Aluminum FreeDrive XC Enduro, 100mm Travel
  • FORK/SHOCK: Fox F32 FRL, Air Spring, Rebound Adjust & Remote Lockout, 100mm Travel; Fox RP23 Air Shock w/ Adjustable Rebound & 3-Setting ProPedal
  • DRIVETRAIN: SRAM X-0 Rear & Shimano XT Front Derailleurs, SRAM X-9 Trigger Shifters; FSA K-Force Hollow Carbon Cranks w/ External Bearings
  • BRAKES: Avid Elixir Carbon Hydraulic Disc, 160mm Rotors
    Product Specs:
    Color(s): Black Anodized
    Frame: New Mongoose FreeDrive W/ 100mm travel, Xtrolite-G6 double butted, shot peened & heat treated alloy, INTEGRATED headset and replaceable hanger
    Fork: Fox F32 FRL Remote 100mm travel, rebound and remote lockout
    Rear Shock: Fox Float RP23, air spring, three position ProPedal, 165x38 mm w/ 19x8 mm hardware
    Crankset: FSA K-Force Lite hollow carbon fiber, 22/32/44T
    Bottom Bracket: FSA Exo Ceramic Bearings
    Pedals: Crank Bros. Candy C
    Front Derailleur: Shimano Deore XT
    Rear Derailleur: SRAM X-0
    Shifters: SRAM X-9 triggers 27 speed
    Freewheel: SRAM PG990 11-32
    Chain: SRAM PC991
    Rims: Stan's ZTR Olympic Disc 32 hole
    Front Hub: Ringle Dirty Flea disc
    Rear Hub: Ringle Dirty Flea disc cassette
    Spokes: Wheelsmith double butted w/ alloy nipples
    Brake Levers: Avid Elixir Carbon
    Handlebar: FSA K-Force Riser carbon fiber/Kevlar composite construction, 31.8x25x630 mm
    Stem: FSA OS-99 cold forged AL7050, 6/4 titanium hardware, 31.8x90 mm
    Grips: Mongoose Lock on
    Saddle: WTB Silveradao Team NiCro tubular rails
    Seat Post: FSA K-Force Lite carbon fiber, doulbe bolt DATA head, 31.6x350
  • << Previous
    Back to the Mongoose booth
    eCycle:
    Contour:
