Interbike 2008 - MTBR
Teocali Comp
2009 Teocali Comp Mountain Bike
FEATURES
  • FRAME: Mongoose FreeDrive All Mountain 6061 Aluminum w/ Zero Stack Headset, Forged Dropouts & Disc Mount, Replaceable Derailleur Hanger, 145mm Travel
  • FORK/SHOCK: RockShox Tora 289 w/ Air Spring, Rebound Adjust & U-Turn 85-130mm Travel; SR/Suntour Epicon Air Shock w/ Rebound Adjust
  • DRIVETRAIN: Shimano SLX/Deore Derailleurs, Deore Trigger Shifters, FSA Alpha-Drive Crankset w/ ISIS Splined Bottom Bracket
  • BRAKES: Tektro Auriga Comp Hydraulic Disc, 160mm Rotors
    Product Specs:
    Color(s): Blue/White
    Frame: Mongoose FreeDrive W/ 145mm travel, zero stack headset and replaceable hanger
    Fork: Rock Shox Tora 289 U-Turn 95-130 mm travel with alloy steerer
    Rear Shock: Suntour Epicon air spring with rebound adjust and rotatable valve, 200x57 mm w/ 19x8 mm hardware
    Crankset: FSA Alpha Drive 22/32/44T ISIS
    Bottom Bracket: FSA ISIS
    Pedals: Mongoose Platform
    Front Derailleur: Shimano Deore
    Rear Derailleur: Shimano SLX, Shadow mount
    Shifters: Shimano Deore 27 speed
    Freewheel: SRAM PG-950 Cassette11-34T
    Chain: Shimano HG73
    Rims: Alex TD24 32 hole
    Front Hub: Formula alloy disc
    Rear Hub: Formula alloy disc cassette
    Spokes: 14g Stainless
    Brake Levers: Tektro Auriga Comp
    Handlebar: Mongoose alloy riser 31.8x30x685 mm
    Stem: Mongoose Alloy Ahead 31.8x90 mm
    Grips: Mongoose Lock on
    Saddle: SDG Bel Air RL steel rail
    Seat Post: 2014 alloy post with double bolt clamp, 31.6x350 mm
  • << Previous Next >>
    Back to the Mongoose booth
    Shimano:
    Crank Brothers:
