Interbike 2008 - MTBR
Teocali Super
2009 Mongoose Teocali Super Mountain Bike
This bike is designed to handle 90% of the riding most of us do. 145 mm of travel and FreeDrive technology keeps the rear end planted to the ground. The lightweight aluminum frame lets you pull tricks that definitely won’t keep your rear end planted to the ground. The new Cobra R adjustable height seat post makes scaling the climbs and ripping the descents a lot easier
FEATURES
  • FRAME: Mongoose FreeDrive All Mountain 6061 Aluminum w/ Zero Stack Headset, Forged Dropouts & Disc Mount, Replaceable Derailleur Hanger, Anodized Frame Finish, 145mm Travel
  • FORK/SHOCK: Fox F32 FRL w/ Air Spring, 15mm Thru Axle, Adjustable Rebound & Lockout, 140mm Travel; Fox RP23 Air Shock w/3-Position ProPedal & Adjustable Rebound
  • DRIVETRAIN: Shimano Shadow XT/SLX Derailleurs, SLX Trigger Shifters; SLX 2-Pc Crankset w/ External Bearings
  • BRAKES: Hayes Stroker Trail Hydraulic Disc, 180/160mm Rotors
    Product Specs:
    Color(s): Black/White
    Frame: Mongoose FreeDrive W/ 145mm travel, zero stack headset and replaceable hanger
    Fork: Fox F32 FRL, 140 mm travel, air spring, rebound and lock out, with 15 mm thru axle
    Rear Shock: Fox Float RP23, air spring, three position ProPedal, extra volume air can, 200x57 mm w/ 19x8 mm hardware
    Crankset: Shimano SLX 22/32/44T Hollowtech II
    Bottom Bracket: Shimano external bearing
    Pedals: Crank Bros. Smarty
    Front Derailleur: New Shimano SLX
    Rear Derailleur: Shimano XT, Shadow mount
    Shifters: Shimano SLX 27 speed
    Freewheel: Shimano HG80 Cassette11-34T
    Chain: Shimano HG73
    Rims: No Tubes ZTR Flow 32 hole
    Front Hub: Formula sealed bearing 15 mm thru axle
    Rear Hub: Formula sealed bearing cassette
    Spokes: DT Competition double butted with alloy nipples
    Brake Levers: Hayes Stroker Trail w/ tool free reach adjust
    Handlebar: FSA XC-190A-OS, triple butted and shot peened AL7050 riser, 31.8x20x680 mm
    Stem: FSA OS-150XT 6 deg. 31.8x90 mm
    Grips: Mongoose Lock on
    Saddle: SDG Bel Air RL titanium rail
    Seat Post: KS Cobra adjustable height w/ remote 31.6x350 mm
  • << Previous Next >>
    Back to the Mongoose booth
    Exustar:
    Chrome:
