Interbike 2008 - MTBR
Boot'R Team
Go ahead, make a Boot’r Call! The Boot’r Team is race spec’d and race proven by Andrew Neethling and Eric Carter; It’s also huck-worthy proven by Romo. 210mm of rear travel incorporated into the FreeDrive system will get you to the bottom faster than ever before. The rubberized powder coat finish will stay pretty for a long, long time.
Check out the Freecaster.tv overview of Andrew Neethling's Boot'R Team
FEATURES
  • FRAME: New Mongoose FreeDrive Downhill 6061 Aluminum w/ Patented Floating BB, 1.5” Headtube, 150 x 12mm Maxle Dropouts, 210mm Travel
  • FORK/SHOCK: RockShox Boxxer Team w/ Motion Control Damping w/ High & Low Speed Compression Damping & Rebound Adjust, 203mm Travel; RockShox Vivid 5.1ST Coilover w/ Piggyback Reservoir, External Beginning & Ending Rebound, Low Speed Compression & Drop Stop
  • DRIVETRAIN: 9-Speed w/ SRAM X-0 Derailleur & X-9 Trigger Shifter; Truvativ Holzfeller TM 36t Crankset w/ External Bearings & E.13 LG Chainguide
  • BRAKES: Avid Elixir Hydraulic Disc, 203mm Rotors
    Product Specs:
    Color(s): Blue
    Frame Material: New Mongoose FreeDrive DH 210mm travel and 150mm Maxle dropouts
    Fork: Rock Shox Boxxer Team, 203 mm travel high/low speed compression, rebound and preload adjust, 20 mm thru axle
    Rear Shock: Rock Shox Vivid beginning and ending stroke rebound and preload adjust, 241x76 mm w/ 19x8 mm hardware
    Crankset: Truvativ Holzefeller OCT 1.1 hollow forged arms 36T ring
    Bottom Bracket: Truvativ Howitzer TM (83 mm shell)
    Pedals: FUNN Sol Jam Viper
    Rear Derailleur: SRAM X.O short cage
    Shifters: SRAM X.9 trigger 9 speed
    Freewheel: SRAM PG-950 Cassette 11-26
    Chain: KMC Z9900
    Rims: SUN A.D.D. Lite 32 hole
    Tires: Kenda Excavator DH w/ Stick-E rubber 26X2.5
    Front Hub: Ringle Jumping Flea 20 mm thru axle
    Rear Hub: Ringle Jumping Flea 150x12 mm thru axle
    Spokes: Wheelsmith stainless
    Brake Levers: Elixir CR pad contact and reach adjust
    Handlebar: Funn Full Bore triple butted AL7075 riser, 25.4x50x710 mm
    Stem: FUNN RS 25.4x45 mm direct attach for Boxxer, CNC alloy
    Grips: Mongoose Lock on
    Saddle: Custom Mongoose SDG Bel Air I-Beam
    Seat Post: SDG I-Beam 2014 alloy, 31.6x250
    Extras: E.13 LG1 ISCG05 chainguide w/ Taco bash guard
  • << Previous Next >>
    Back to the Mongoose booth
    SportLegs SALE:
    Hutchinson:
