Interbike 2008 - MTBR
Boot'R
2009 Mongoose Boot'R Full Suspension Bike
The Team version’s bike park little brother. If you’re more the jeans and a T rider, this is your bike.
FEATURES
  • FRAME: New Mongoose FreeDrive Downhill 6061 Aluminum w/ Patented Floating BB, 1.5” Headtube, 150 x 12mm Maxle Dropouts, 210mm Travel
  • FORK/SHOCK: Marzocchi 888 RCV w/ Preload, Compression & Rebound Adjust, 200mm Travel; Marzocchi ROCO R Coilover w/ Rebound & Preload Adjust
  • DRIVETRAIN: 9-Speed w/ Shimano Saint Derailleur & SLX Trigger Shifter; Truvativ Hussefelt 36t Crankset w/ External Bearings & E.13 LG Chainguide
  • BRAKES: Hayes Stroker Trail Hydraulic Disc , 203mm Rotors
    Product Specs:
    Color(s): Black
    Frame Material: New Mongoose FreeDrive DH 210mm travel and 150mm Maxle drops
    Fork: Marzocchi 888 RCV 200 mm travel, rebound, compression and preload adjust, 20 mm thru axle
    Rear Shock: Marzocchi ROCO R rebound and preload adjust, 241x76 mm w/ 19x8 mm hardware
    Crankset: Truvativ Hussefelt with cromoly pedal inserts1.0 36T ring
    Bottom Bracket: Truvativ Howitzer TM (83 mm shell)
    Pedals: Mongoose Alloy platform with replaceable pins
    Rear Derailleur: Shimano Saint Shadow with SS cage
    Shifters: Shimano SLX 9 speed
    Freewheel: SRAM PG-950 Cassette 11-26
    Chain: Shimano HG73
    Rims: SUN MTX-31 32 hole
    Tires: Kenda Excavator DH w/ Stick-E rubber 26X2.5
    Front Hub: Sealed bearing 20mm thru axle
    Rear Hub: Sealed bearing 150x12 thru axle casstte
    Spokes: DT Champion 14G stainless
    Brake Levers: Hayes Stroker Trail w/ tool free reach adjust
    Handlebar: Funn Full Bore triple butted AL7075 riser, 25.4x50x710 mm
    Stem: FUNN MZ2 25.4x45 mm direct attach for Marzocchi, CNC alloy
    Grips: Mongoose Lock on
    Saddle: Custom Mongoose SDG Bel Air I-Beam
    Seat Post: SDG I-Beam 6061 alloy, 31.6x250
    Extras: E.13 LG1 ISCG05 chainguide w/ Taco bash guard
  • << Previous Next >>
    Back to the Mongoose booth
    Fox 360 Jersey:
    Formaggio:
