Interbike 2008 - MTBR
Pinn'R Apprentice
2009 Mongoose Pinn'R Apprentice Dual Suspension Mountain Bike
This is Romo’s big mountain/back country Freeride bike, reflected both in its spec and in its style. This bike is at home at your local bike park; the 190 mm of travel is perfect for the Romo-philes out there.
FEATURES
  • FRAME: New Mongoose FreeDrive Freeride 6061 Aluminum w/ Patented Floating BB, 1.5” Headtube, 150mm Maxle Dropouts, 190mm Travel
  • FORK/SHOCK: Marzocchi 66 RCV w/ Preload, Compression & Rebound Adjust, 180mm Travel, 20mm Tool-Free Thru-Axle; Fox Van R Coilover w/ Piggyback Reservoir, Rebound & Preload Adjust
  • DRIVETRAIN: Shimano SLX 9-Speed Derailleur & Deore Trigger Shifter; Gravity Step Up 36t Crankset w/ External Bearings & E.13 LG Chainguide
  • BRAKES: Avid Juicy 3 Hydraulic Disc, 203mm Rotors
    Product Specs:
    Color(s): Black
    Frame Material: New Mongoose FreeDrive Free Ride 190 mm travel w/ 150mm Maxle dropouts
    Fork Material: Marzocchi 66 RCV, 180 mm travel, rebound, compression, and preload adjust, 20 mm QR thru axle
    Rear Shock: Fox Van R rebound and preload adjust, 229x70 mm w/ 19x8 mm hardware
    Crankset: Gravity Step Up with cromoly pedal inserts 36T
    Bottom Bracket: Gravity ISIS (83 mm shell)
    Pedals: Mongoose Alloy platform
    Rear Derailleur: Shimano SLX, Shadow Mount GS cage
    Shifters: Shimano Deore 9 speed
    Freewheel: SRAM PG-950 Cassette11-34T
    Chain: Shimano HG73
    Rims: SUN Ditch Witch 32 hole
    Tires: Kenda Excavator DH w/ Stick-E rubber 26X2.5
    Front Hub: Sealed bearing 20mm thru axle
    Rear Hub: Sealed bearing 150x12 thru axle casstte
    Spokes: 14G stainless
    Brake Levers: Avid Juicy 3
    Handlebar: Funn Fatboy triple butted AL7075 riser, 31.8x30x710 mm
    Stem: Funn Rippa 31.8x45 mm CNC alloy
    Grips: Mongoose Lock on
    Saddle: Custom Mongoose SDG Bel Air I-Beam
    Seat Post: SDG I-Beam 6061 alloy, 31.6x300
  • << Previous Next >>
    Back to the Mongoose booth
    EnduraFuel:
    eCycle:
