Interbike 2008 - MTBR
Khyber Super
2009 Mongoose Khyber Super Mountain Bike
Named for Whistler’s famed Khyber pass, this bike will take anything you throw at it. Not that you ever forgot, but with 165 mm of travel courtesy of Marzocchi front and rear suspension, this “up and down” bike reminds you why mountain biking is so fun. The addition of the Cobra R adjustable height seat post only adds to the fun.
FEATURES
  • FRAME: Mongoose FreeDrive All Mountain/Freeride 6061 Aluminum w/ Patented Floating BB, 135mm Dropouts, 165mm Travel
  • FORK/SHOCK: Marzocchi 55 ATA Micro w/ Air Spring, 125-165mm Adjustable Travel, Rebound, Micro Compression & Preload Adjust, 15mm Tool-Free Thru Axle; Marzocchi ROCO Air R Piggy Back w/ 5-Position Compression & Rebound Adjust
  • DRIVETRAIN: Shimano XT Rear & SLX Front Derailleurs; Shimano SLX Trigger Shifters; SLX 22/36t Crankset w/ Bashguard & External Bearings; MRP Long Range Patrol Dual Ring Chain Keeper
  • BRAKES: Hayes Stroker Trail Hydraulic Disc, 203mm/180mm Rotors
    Product Specs:
    Color(s): Black Nickel
    Frame: Mongoose FreeDrive All Mountain/Free Ride, 165mm travel, 135mm vertical drop outs
    Fork: Marzocchi 55 ATA Micro 125-165 travel adjust, micro compression adjust, nickel stanchions, air spring with progressive bottom out, 20 mm QR thru axle
    Rear Shock: Marzocchi ROCO Air R, 5 position compression, bottom out resistance, oversize air can, and rebound adjust, 216x63 mm w/ 19x8 mm hardware
    Crankset: Shimano SLX 22/36T/BASH Hollow Tech II
    Bottom Bracket: Shimano external bearing
    Pedals: Crank Bros. Acid
    Front Derailleur: Shimano SLX for 22/36T combo
    Rear Derailleur: Shimano XT, Shadow mount
    Shifters: Shimano SLX 18 speed
    Freewheel: SRAM PG-950 Cassette11-34T
    Chain: Shimano HG73
    Rims: No Tubes ZTR Flow 32 hole
    Front Hub: Formula sealed bearing 15 mm thru axle
    Rear Hub: Formula sealed bearing cassette
    Spokes: DT Competition double butted with alloy nipples
    Brake Levers: Hayes Stroker Trail w/ tool free reach adjust
    Handlebar: Gravity Light, triple butted and shot peened AL7050, 31.8x 25x710 mm
    Stem: Gravity Light, 31.8x50 mm
    Grips: Mongoose Lock on
    Saddle: SDG Bel Air RL cromoly rail
    Seat Post: Cobra R adjustable height w/ remote 31.6 x 350 mm
  • << Previous Next >>
    Back to the Mongoose booth
    Mountain Cycle:
    Avid:
