Interbike 2008 - MTBR
Nugget
2009 Mongoose Nugget Dual Suspension Bike
There’s no “work hard”, just “play hard” when you’re riding the Nugget. The low-slung geometry on the 100mm travel frame is equally at home hitting Slopestyle tricks, dirt jumps or even mountain cross/slalom racing.
FEATURES
  • FRAME: Mongoose FreeDrive Slopestyle 6061 Aluminum w/ Patented Floating BB, Adjustable 100mm Travel
  • FORK/SHOCK: RockShox Pike 409 w/ Rebound Adjust, 95-140mm U-Turn Adjustable Travel and Alloy Steerer; RockShox Monarch 3.1 Air Shock w/ Motion Control Damper, Externally Adjustable Floodgate Setting & Rebound
  • DRIVETRAIN: 9-Speed w/ SRAM X-7 Derailleur & Trigger Shifter; Truvativ Hussefelt 36t Crankset w/ External Bearings
  • BRAKES: Avid Juicy 3 Hydraulic Disc, 160mm Rotors
    Product Specs:
    Color(s): White
    Frame Material: New Mongoose FreeDrive Slopestyle frame w/ 100 mm rear travel and 135mm Maxle dropouts
    Fork: Rock Shox Pike 409 140 mm travel U-turn Adjustable, 20 mm Maxle
    Rear Shock: Rock Shox Monarch 3.1
    Crankset: Truvativ Hussefelt with cromoly pedal inserts 1.0 36T ring
    Bottom Bracket: Truvativ Howitzer XR
    Pedals: Mongoose Alloy platform with replaceable pins
    Rear Derailleur: SRAM X.7 medium cage
    Shifters: SRAM X.7 9 speed
    Freewheel: SRAM PG-950 Cassette 11-26
    Chain: Shimano HG73
    Rims: SUN Ditch Witch 32 hole
    Tires: Kenda Small Block Eight 26X2.35
    Front Hub: Sealed bearing 20mm thru axle
    Rear Hub: Sealed bearing 135x12 thru axle casstte
    Spokes: 14G stainless
    Brake Levers: Avid Juicy 3
    Handlebar: Funn Full Bore triple butted AL7075 riser 25.4x50x710 mm
    Stem: Funn Rippa 25.4x45 mm CNC alloy
    Grips: Mongoose Lock on
    Saddle: Custom Mongoose SDG Bel Air I-Beam
    Seat Post: SDG I-Beam 2014 alloy, 31.6x250
    Extras: E.13 LG1 ISCG05 chainguide w/ Taco bash guard
  • Next >>
    Back to the Mongoose booth
    eCycle:
    Niner:
