Interbike 2008 - MTBR
Force Carbon Pro
New for 2009, this six-inch carbon trail bike was previously only available in aluminum. Thanks to new carbon construction that shaved more than 1 pound off the frame, the Force Carbon Pro now comes in at a sleek 26.5 pounds – delivering lively climbing response and exhilarating downhill velocity. This all-XTR bike is one of five models in the Force lineup, including three aluminum and two carbon fiber bikes.
Headset: FSA integrated sealed bearing
Stem: Thompson Elite X4
Grips: GT Lock Down, co molded locking grip system
Rear Brake: Shimano XTR Disc, 160mm rotor
Brake Levers: Shimano XTR Hydraulic
Handlebar: Ritchey Carbon WCF Rizer 31.8 clamp, low rise
Spokes: Mavic CrossMax ST disc
Nipples: Alloy
Front Brake: Shimano XTR Disc, 180mm rotor
Rear Hub: Mavic CrossMax ST disc
Front Hub: Mavic CrossMax ST disc
Tires:
Front: 26"x 2.3 Kenda Nevgal, 120 tpi with Kevlar bead, Rear: same only 2.1
Rims: Mavic CrossMax ST disc with 15 mm front through axle
Rear Derailleur: Shimano Shadow XTR
Shifters: Shimano XTR
Rear Cogs: Shimano XT 11-34t
Chain: HG-73 Nine Speed
Pedals: N/A
Front Derailleur: Shimano XTR
Saddle: FIZIK Gobi XM with manganese rails
Bottom Bracket: Shimano XTR Outboard
Crankset / Chainwheel: Shimano XTR 44/32/22
Fork: Fox TALAS 32 RL wth QR 15 through axle system adjustable travel from 110 - 150mm with air spring pressure and rebound adjust with 7050 aluminum steerer
Rear Shock: Fox Float RP23 Shock
Seat Post: Thompson Elite
Seat Clamp: GT Alum QR
<< Previous Next >>
Back to the GT booth
Chrome:
Kenda:
