Interbike 2008 - MTBR
Zaskar Carbon Team
The iconic Zaskar is the only hard tail to win in all disciplines: Cross Country, 4X, Dual slalom, Trials and Downhill. This light, stiff and fast bike comes in three carbon models (Team, Pro and Expert).
Grips: GT Lock Down
Stem: Ritchey 4 Axis MTB stem with CNC machining and 4 bolt face plate
Handlebar: Ritchey Carbon WCS Flat with 31.8 mm clamping area.
Brake Levers: XTR seperate Hydraulic
Front Brake: XTR Centerlock Disc 160mm rotor
Rear Brake: XTR Centerlock Disc 140mm rotor
Front Hub: Mavic SL Disc for Centerlock
Rear Hub: Mavic SL Disc for Centerlock
Spokes: Mavic Alloy Zicral spokes
Nipples: Mavic M7 alloy
Tires: Front: 26"x 2.0 Kenda Karma 120 TPI with kevlar bead, Rear: same only 2.1
Rims: Mavic SLR Disc for Centerlock, with SUP welded Maxtal ISM rim, 24 Alloy Zicral spokes fnt and rr with alum nipples, 1502 grams / pair
Chain: Shimano 9 speed
Rear Cogs: Shimano XTR Nine speed index cassette 11-32
Shifters: Shimano XTR trigger
Pedals: N/A
Front Derailleur: Shimano XTR
Rear Derailleur: Shimano XTR Shadow with Carbon pulley cage
Headset: FSA Integrated, sealed angular contact bearing
Bottom Bracket: Shimano XTR outboard oversize bearings
Crankset / Chainwheel: Shimano XTR, 2 piece design, 22, 32, 44
Fork: FOX 32 RL with 100mm of travel, rebound adjust and remote lock out
Frame: GT design, force optimized, full monocoque carbon frame with replaceable der hanger
Saddle: FIZIK Gobi XM with Manganese Rails
Seat Post: Thompson Elite
Seat Clamp: GT Alum QR
<< Previous Next >>
Back to the GT booth
Contour:
Niner Bikes:
