Interbike 2008 - MTBR
2009 Fury
New for 2009, this first-of-its-kind downhill bike features a full monocoque carbon fiber frame and a Rock Shox Boxxer World Cup fork with 8” of travel. World Cup pro downhiller Bryn Atkinson is racing this lightweight, stiff bike, which features a new Shimano Saint component group and Avid Code carbon hydraulic disc brakes.
Seat Clamp: Alloy forged
Grips: GT alloy Lock Down
Headset: FSA Orbit Z 1.5 R cold forged alloy cups for 1.5 headtube with sealed cartdride ACB bearings, with internal reducers for 1 1/8 steerer, 9mm total stack
Saddle: WTB Rocket V Pro, with Cr-mo Rails
Seat Post: Thompson zero offset, CNC turned USA made 2014 seatpost, 31.6mm by 350
Stem: FUNN RSX Direct mount for Boxxer, full CNC 30 degree rise, for 31.8 bar bore
Handlebar: FSA Carbon DH. 31.8mm bar bore, 25 mm rise with 8 degrre sweep 3 degree tip
Brake Levers: Avid Code
Rear Brake: Avid Code, 160 mm rotor
Front Brake: Avid Code, 203 mm rotor
Nipples: DT brass
Spokes: DT 2.0 stainless
Rear Hub: DT / Swiss FW 440 for 12 mm Axle
Front Hub: DT / Swiss FW 440 for 20 mm Axle
Rims: Kenda Nevegal, 2.5" DH with "Stik-E" compound, butyl cap and sidewall reinforcement
Tires: Kenda Nevegal, 2.5" DH with "Stik-E" compound, butyl cap and sidewall reinforcement
Rear Cogs: Shimano
Chain: Mavic EX-729, welded joint with Maxtal alloy material
Shifters: Shimano Dura Ace nine speed 12 - 25
Pedals: Shimano New Saint
Front Derailleur: Shimano New Saint short cage
Rear Derailleur: Shimano New Saint 9 speed
Frame: Full Monocoque Carbon Fiber with forged and CNC fitments, with all new I link assembly and pivot design for 8.65 inches of rear wheel travel with Maxle rear axle QR system
Rear Shock: Rock Shox Boxxer World Cup, 203 mm travel, Air sprung, with preload, rebound and compression damping, with Motion Control and Maxle 20mm frnt axle
Fork: FOX DHX AIR 5.0, Air sprung damper with rebound and compression adjust and platform adjust
Bottom Bracket: Shimano New Saint with 38 tooth ring
Crankset / Chainwheel: E-Thirteen SRS Light guide with chain taco for 38 tooth ring.
Next >>
Back to the GT booth
Chrome:
Avid:
