Interbike 2008 - MTBR
02 PVA
The X-Fusion O2 PVA is revised for 2008! The highest performance pedaling platform shock just got better. Four stages of PVA are now clearly indicated and easier to adjust. New seal and o-ring designs reduce friction by 25% improving small bump performance. New air sleeve design and 7075 aluminum shaft reduce weight to 218g making the O2 PVA the best performing rear shock on the market.
• New Power Valve II 4 stage adjustment
• New Light Weight Design. (apr. 218g.)
• New improved adjuster knob design
• New air sleeve design for better spring ramp
• Standardized 12.7mm eyelet width
• 25% less movement friction
• Ø15mm DU shaft hole.(org,14mm)
• DU bushing up grade for more durability.
• New Ball bearing option
• New 7075 aluminum shaft
• Externally adjustable rebound damping
• Multi-circuit damping
• Nitrogen charged IFP
• Infinitely adjustable air spring
<< Previous Next >>
Back to the X-Fusion booth
FSA:
Rock Shox:
