Interbike 2008 - MTBR
Amp ( DJ / 4X / Pump)
The amp is tight, light and ready to take flight! With 400-425mm chainstay with horizontal dropouts welded to light but stiff internally ribbed chain and seat stays that back end of the frame is slammed, which makes manualing a breeze, and rotations in the air a walk in the park. The Amp uses a 7005 T6 custom hydro-formed triple butted tube set with integrated gusseting for high strength with minimal weight. At the front you will find a precision machined head tube, compatible with lightweight zero stack integrated headsets to keep the weight down and the front of the bike low. What does all this mean? It means that the frame feels perfectly at home high in the air at your local jump spot, and can accelerate out of the gate faster than any other if you feel like racing some 4X. It means that you can ride a bike that can take the abuse that you throw at it, but only weighs 2kg (4.4lbs). All in all this bike will be more nimble, faster, stronger, lighter and easier to do tricks on due to super low standover than any other bike out there.
Features:
7005 T6 frame with custom hydro-formed tubeset and internally ribbed chain and seat stays.
Horizontal dropouts
Integrated headset compatible 45/45degree standard
Weight: 4.4 lbs
Sizes: Regular, Long
Colors: Raw w/ Gloss Clear Coat
Headtube: 1-1/8" Hourglass
135mm rear hub spacing
Tubeset: 7005 Al Banshee Custom Hydroformed Tubing
<< Previous Next >>
Back to the Banshee Bikes booth
Niner Bikes:
Salsa:
