Interbike 2008 - MTBR
Discuss Gravity Dropper Products
Read and Write Reviews on Gravity Dropper Products
Visit the Gravity Dropper website
(note: Gravitydropper was not at Interbike this year. However, they provided us with these pictures to feature their products. The booth image above is from their Downieville Classic booth.)
Gravitydropper was introduced in 2003. We specialize in mechanical “On the fly” adjustable height seatposts. We manufacture, and assemble our high quality, high performance product in-house located in Polson, Montana. USA. We credit our success to a great, dependable product and strive to offer incredible customer service.
We make 3 different versions. Descender, Gravitydropper classic and the Gravitydropper Turbo
  • They are available in 3 different heights. A person can order a 2 inch or a 3 inch , or a 4 inch drop.
  • They come in a standard up/ down or with a multi-position (3 positions) We believe that knowing where you are at is more important than having an infinite number of positions
  • All the post have a locked feel. When your post is in the up position, it will not change. Same with the down position, the post will only raise up when you activate it.
  • The shorter seatposts weigh even less than the longer ones
  • We offer lengths from 275- 425mm long.
  • They come in 27.2 diameter. We offer shims for larger sizes
  • The post is mechanical which means it just uses a spring that has a rating of 10 million cycles. There is no air, or pumping, no seals to leak or oil to blow out. This means that it is very easy to take the inside tube out and clean. This takes 30 seconds to perform.
  • When the post slides up and down. Only plastic touches aluminum. This is an incredible feature for two reasons. 1) The post wears the plastic first so if you ever develop side to side wiggle, just put new plastic shims in and it is just like brand new. 2) very easy and cheap to install the new plastic shims. (item #42)
  • All our parts are cnc machined out of aluminum, most of it 7075 t-6 aluminum.
  • Because we offer so many lengths and drops, each post is made to fit you the way you ride and the type of bike you have.
    To order or get more information, call our sales office at 406-883-3555 or e-mail sales@gravitydropper.com or check out the website at www.gravitydropper.com
  • Featured Product: Gravity Dropper in the Alps
    -Made in the USA from CNC'd 7075 T-6 aircraft aluminum.  This high grade aluminum allows for strong lightweight units.
    -Weight.  The whole seatpost, including all hardware, switch and cables is 450 grams. &...
    Read more >>
    Gravity Dropper
    Descender
    Turbo
    Gravity Dropper
    Gravity Dropper
    Gravity Dropper
    Gravity Dropper
    Gravity Dropper
    Gravity Dropper
    Interbike - Trade Show Booths
