FrameCustom geometry Ti frame, heavy guage for grinding and the like, tubular conduit internal brake routing through downtube
Front Fork1.5" rigid Ti with 400mm axle to crown and 20mm dropouts
Bottom BracketX-type Diabolus
Crankscustomized flysports propeller style: thicker guage tubing, grind plates, spline driven crainring, and other sundry engineering editing
Chainringsboone
PedalsNS bikes Leg Eater, white, mostly just cuz they look cool and are sticky like poo
Chain1g8 w/ green inner and outer links
CogsetSpot
HubsSpot rear G-sport front
Spokescx-ray
Rimsheat treated, machinedf and double eyletted gloss anodized Singletrack
Brakeshope mono 4 black caps
Saddlecustom 1-piece cross between macneil and thomson, in carbon with green suede cover
HeadsetNicolai fett set
Stempink lugged steel
Handlebarsorange funn kilobar
Brake Leverscarbon blades
Bar Tapeleather
Extrasti parts anodized orange or green, frame two tone lengthwise bands
Dominic from Montreal writes:
Why? Cause you guys are a bunch of unimaginative prats!
BACK to the Dream Bikes Section
Hutchinson:
Easton:
