RockShox Lyrik RC2DH Solo Air 2015 Forks
/5
REVIEWS
0.0
QIKRATE
0.0
WEB
0.0
Own this? Be the first to rate it! (Tap a star to rate) |
DESCRIPTION
Rock Shox Lyrik RC2DH Solo Air ForksThe Lyrik rsquo;s already epic offering just got leaner and meaner. Sure, the efficient and nimble 35mm chassis design will get you to the top of the mountain. But it rsquo;s the smooth control on the downhill that will drive you to go back to the top again and again.Lyrik got meaner and leaner. The new Lyrik combines climbing prowess and downhill control through a BoXXer-derived Mission Control DH damper. Master the mountain with Lyrik's 160 or 170mm travel options, all new air spring systems and a stout 35mm structure. Specifications: Travel: 170mm Weight: Solo Air: 2180g *Weight based on 265mm 1-1/8 steerer with 20mm Maxle Lite Damping: Mission Control DH, External rebound, high speed compression and low speed compression Adjustments: External rebound, high speed compression and low speed
