SRAM XX1 Component Group
DESCRIPTION
The Sram XX1 group is constructed with precision engineering to create a maximum-performance group like no other. This 1x11 drive offers an enormous cassette to be matched with 1 of 6 available chaining options to fine-tune your preference and riding styl
USER REVIEWS
Showing 1-7 of 7
[May 07, 2015]
Zachariah
All Mountain Rider
OVERALL
RATING
5
VALUE
RATING
5
Strength:
~ Dropped 378g off my bike, coming from 2x10
~ XX1 Gripshifter changes gears like lightning
~ XX1 Clutch rear derailleur has zero chain slap
~ Narrow-wide chainrings do not require further chain retention device
~ 256g 10-42 cassette is a work of CNC art
Weakness:
~ Alloy OEM chainrings wear out way too fast - must upgrade to Wolftooth, North Shore Billet or Absolute Black
~ Groupset alone costs as much as mid-level hardtail
If you see yourself in the granny ring more than 80% of the time.....going 1x11 is going to make things much simpler. Plus, it simply makes one a stronger rider, in the long run. There is no need to pay up to $1400 for full 1x11....shop smart and patiently and you can realistically buy part-by-part, NEW for well under $900. Let me tell you - it is WELL WORTH IT!!!
I will never go back to 2x10....
Similar Products Used:
Shimano XTR M9000
[Oct 10, 2014]
JW
Cross Country Rider
OVERALL
RATING
5
VALUE
RATING
5
Strength:
Light weight, simplicity of setup, Dependability.
Weakness:
Cost
I purchased a SC Tallboy Carbon this spring with XX1x11 drivetrain and wasn't sure at the time that I was sold on the single chainring design, but after riding it for a season, I'm totally sold and can't imagine going back to multiple. I feel iike I'm always in the right gear while riding and have not had to make a single adjustment to the derailleur all season. It takes only 5 minutes to switch out the chainring for different conditions; killer steeps at altitude=28, and a more rolly ride might be a 32. I haven't changed my ring this summer, but my wife does for races.
Shimano XT
[Apr 14, 2014]
Chris
All Mountain Rider
OVERALL
RATING
5
VALUE
RATING
Strength:
Quiet when new. Great shifts. No front derailleur to think about , hassle with or weigh you down. Never dropped a chain. 10 tooth rear cassette.
Weakness:
Aftermost of a full season. Maybe 100-150 hrs I have some noise related wear issues.
Unless you are a front pack racer or like to avoid hills this drivetrain works best with a 28 tooth ring up front. I did a lot of research on formulas to compare the ratios taking into consideration wheel size, crank arm length, and all the gear combinations. bottom line the 28 X 42 combo with 650B wheels is equivalent to your 26 inch wheel 24 X 34 for a lowest gear. If you do long climbs, steep technical climbs and you don't like walking don't even think about the 32 or 34 up front. You would lose half a gear with the 30 but why bother. The ten tooth at the back is what makes this way better than the new Shimano 11 speed. Basically your top gear is ten percent stiffer than an 11 tooth and this is what gives this system the range. Ive lost basically one gear from my 2X system with a 34 big ring. My issue for value is a combination of price and wear. I have not solved the noise issue but a new chain makes it worse so either the cassette or the front ring is causing the sound under harder pedalling. I am hoping it is the front ring. It is the only ring so it never gets a break and at 28 teeth it goes around and around a lot. The chain wear was measured at only 50% of normal wear tolerance for a nine speed, about 1/16th inch. If the rear cassette needs to be replaced thats MSRP at $400 plus $100 for the front and then the new chain at $60 would put you up to $600 with taxes. Thus a questionable value for about 6 and a half months of regular riding. I have loved the first six. Derailleur has been flawless.
Several hours of testing by a top mechanic and we are hoping it is the front ring which would put a chili back on for value..
Shimano, Blackspire, shram
[Dec 17, 2013]
DeeZee
Cross Country Rider
OVERALL
RATING
5
VALUE
RATING
4
Strength:
Shifting is phenomenal, quiet, easy to change the front chain ring if needed and looks sexy
Weakness:
You knew it was coming....price. Also not sold on this groupo for every type of bike.
Earlier in the year I decided to build a light HT for racing and the XX1 seemed perfect.....and it is! No dropped chains and shifts fast and crisp.
However I have a FS bike that I use for longer rides with more elevation / chunk. It has a 2x10 drive train. For this bike and the type of riding I do with it I am not sure if I should switch to 1x11. Sometimes on longer endurance rides you just need to shift into a higher gear and recover.
SRAM XX0 2x10
SRAM XX0 1x1 (SS)
[Nov 27, 2013]
Aljaz Anderle
All Mountain Rider
OVERALL
RATING
5
VALUE
RATING
4
Strength:
Simplicity, silence, range, weight, looks
Weakness:
price, ratio choice
Preformance-wise there is nothing to comment. It is great. So reliable, strong and well designed. I use it on my 29 enduro bike, which I regularly take on long alpine tours, with hours of climbing. Therefore, my only option was to put a 28t up front. I can climb everything with it but it drains me a little faster than an old 2x10 I had used before. Rumours about the 44 rear cog option are hopefully about to come true. If I ride with friends, it is hard to maintain their pace because the bike just runs faster. A harder gear plus the 29...
I have bought a second chain, the kmc, which also works just fine. It is important to set the chain length precisely right, otherwise problems with shifting might ocurr, especially on full suspension bikes. The biggest benefit is quietness of the ride, no chain slapping, no chain falling off. The ground clearence is also much higher.
Sram x9, sram x0
[Aug 25, 2013]
CanmoreC
OVERALL
RATING
5
VALUE
RATING
4
Strength:
Simple design
Lite weight
Awesome looking cassette
Weakness:
Early in production
Expensive
Love the xx1 system! Its simple and easy to use (combined with the grip shifter). I have it on my giant trance x29er with a 32tooth front sprocket. I ride xc/technical xc/all mountain and it works just great. The last 5 years I have done a lot of road riding and I think this was good training for the xx1. Keeping your cadence and momentum up with the xx1 can be important.
Only gave it 4 chili's for value as I have had a small warranty issue with a broken part in the grip shift (fixed under warranty).
I do not miss the 2x10 or 3x10 systems at all.
[May 05, 2013]
Professed
OVERALL
RATING
4
VALUE
RATING
Strength:
so simple and intuitive to use. works brilliantly when new and correctly set up. chain retention excellent when new.
Weakness:
chain length is critical - only cut chain when at maximum sag. performance of chain retention declines rapidly with wear
A truly brilliant addition to mountain biking. The range of gearing, whilst seemingly limited, is in reality not limited at all as shifting through the range is so simple, quick and intuitive. works just as well with grip shift as with trigger.
Very strong rear steel cassette. very strong and reliable chain and chain ring. fantastically stiff cranks.
Chain length is CRITICAL. too short and you will break locating screws (like I did). Too long and your chain will fall off. Chain retention is uneccesary except for very bad conditions and for when your front chain ring starts to wear. Mine is now 4 months old and has started to drop the chain in rough conditions without chain retention.
Quality of jockey wheels a bit suspect - I have broken two already and parts are very hard to source.
Excessive use of TORX head screws throughout the groupset is really annoying as the market is moving back to hex head. Stop using TORX screws please !!!
with some more refinement this drivetrain is likely to become the standard for MTB. I cant think of anything more you will need except for say touring where you need big ratios for long downhills on tarmac or tiny gears for massive and long climbs.
MTBR Newsletter
Get the latest mountain bike reviews, news, race results, and much more by signing up for the MTBR Newsletter
© Copyright 2024 VerticalScope Inc. All rights reserved.
