Fox Shox 32 Float 140 RL Fit 2012 Forks
DESCRIPTION
The Fox Racing Shox 32 Float 140 RL FIT sports travel that ten years ago was reserved for the rising freeride movement. Those forks were quite portly, and frame designs have come a long way since then. Bikes that populate local trails now offer travel that was once considered too excessive for regular ol' cross-country riding.Most important, however, is the enhancement of ride dynamics and performance levels that now match that of motorsports. It's due directly to features like this 32 Float's 15mm thru-axle and its hollow truss-to-seal flange that ensures weight is minimized. But, more importantly, this enhances the overall chassis stiffness for unparalleled steering precision and reduced binding.Complementing the 32 Float 140's flex-fighting chassis is Fox's FIT damper. This unit employs a bladder to keep air and oil from mixing and negatively affecting performance. Fluid aeration results in a reduced damping, which will cause the fork to lose its ability to control movement.The FIT damper, unlike open bath dampers, is also inverted. This means the fork's unsprung weight is lower for less inertia to control -- resulting in a more sensitive, plusher fork. The Fork uses an air spring that's simple to adjust via the top-cap-mounted Schrader valve. Under the right leg there's an indexed rebound adjustment knob.The Fox Racing Shox 32 Float 140 FIT comes in Black with Custom logos, or Black with Black and White logos.
MTBR Newsletter
Get the latest mountain bike reviews, news, race results, and much more by signing up for the MTBR Newsletter
© Copyright 2024 VerticalScope Inc. All rights reserved.
