Hayes Replacement Pads Brake Pad
Best Price At
USER REVIEWS
Showing 1-10 of 17
[Oct 06, 2009]
Ecogeek
Cross Country Rider
OVERALL
RATING
VALUE
RATING
Strength:
They stop the bike.
Weakness:
They don't stop the bike as well as any alternative pad I've tried.
Serfas. Alligator. Organic. Ceramic. Sintered or not. Anything at all, cheap, not cheap, will stop the bike better than these. Usually for less money.
I have cleaned them, sanded them, the same with the disks. I've tried a brand new set. I've switched front to back and so on, but nothing gets them as good as they should be. Whatever you try, try another brand of pad. One of these also decided to crumble to dust for some reason. No, not from all the sanding/cleaning!
I'll give them a 'fair' rating as they do stop the bike, but considering the price, for value and overall performance they're the worst I've tried. They also seem to like to squeal more than most too. I have run these on two bikes in four calipers from new. I persisted for some time. But as soon as I started trying other brands, things got much better and seem to stay that way whatever other brand I try.
[Sep 09, 2007]
Joseph Miller
Weekend Warrior
OVERALL
RATING
5
VALUE
RATING
5
Strength:
These brakes can stop extremely quick. Sure would not hit the front brake first if going fast.
Weakness:
None. Excellent stopping.
These brakes came installed on my bike. Never really gave much concern about bike brakes untill today. Was riding my favorite trail today which is the Salt Creek Trail. At one point you go under some railroad tracks where you have to duck down to pass under. A kid and his dad was creeping along at a very slow speed. Other bikes were comming towards me. I was probably a bit fast but these brakes kept me from plowing into this little child. If I had standard brakes I sure would have hit this little guy. I highly recommend these to all. THANKS HAYES FOR AN EXCELLENT PRODUCT
Similar Products Used:
Lever brakes
[Jul 21, 2007]
Colin Hall
Cross Country Rider
OVERALL
RATING
5
VALUE
RATING
4
Strength:
Will stop your bike dead! Last for a long time under demanding conditions. They need properly braking in but once on and worn they haven’t given me any problems. Been using Hayes for over 6 years
Weakness:
Price, $40 per set for Sintered pads is a bit pricey
Good pads but on the pricey side.
none
[Feb 13, 2007]
John
Weekend Warrior
OVERALL
RATING
5
VALUE
RATING
5
Strength:
Durability, weight, red colour & only 2/3 the price when compared to LBS prices.
Weakness:
None.
This review is for the *Kool Stop/High Performance Compound/KS-D200* version of replacement disk pads. The stock Hayes pads lasted me from July 2002 to March 2005. I got these at M.E.C. back in early 2005 to test on my 2001 Trek Fuel 90 Disk for my front wheel for the 2005 & 2006 cycling seasons. My stock Hayes (front) pad was only 10% worn and the rears were 70% worn. So I put the front pads on the rears and put new Kool Stop pads on the front. They acted the same way, stopping me very quickly with few squeaks. For my next cycling season starting March 2007 as soon as all the snow & ice have melted, I'll be installing a second set of pads that I got in my order with M.E.C. back in early 2005. I mainly ride on city streets, sidewalks & waterfront bike paths. The price for 1 set of replacements pads at my LBS were $25 and I ended up getting 2 sets thru M.E.C. for $30. There is also a M.E.C. version for $5 but are of the - regular organic compound for average riding conditions.
Bottom Line: Excellent pads that work, act and sound like stock Hayes at nearly 1/2 the price when found at LBS.
Stock Hayes Disk Pads.
[Jan 18, 2007]
Saber Haghvirdy
Downhiller
OVERALL
RATING
VALUE
RATING
Strength:
acceptable friction - not bad over all
Weakness:
wears very fast and when wet super fast . When muddy take a pair of extra pads with yourself on the trail.
They perform very good but wear out prety fast.
Avid - Jagwire
[Oct 18, 2005]
Roundy
Weekend Warrior
OVERALL
RATING
VALUE
RATING
Strength:
I'm struggling to think of some
Weakness:
The stuff that these are made of gives no grip at all!
These pads suck.
Hope pads are different nearly every year. They seem to change the supplier like an actress changes her clothes and the present compound is a joke!
Fibrax. EBC
[Apr 28, 2007]
timish horbay
Downhiller
OVERALL
RATING
5
VALUE
RATING
4
Strength:
long lasting- i dont care who tells you these dont last long, a full season at whistler and mine are still going
good power- they are way better than stock
modulation-enough to have control but not mushy feeling
Weakness:
noisy as hell
really easy to glaze while bedding in
these are good. they stop you all season long, what else could you want. i am a big guy (220lbs) and they have no trouble stopping me... anybody who has problems didnt bed the pads right and glazed them, and they deserve bad brakes!
hope pads
cheaper hayes pads
aztec pads
[May 20, 2007]
Lee Crowell
Cross Country Rider
OVERALL
RATING
5
VALUE
RATING
5
Strength:
good stopping power
Weakness:
none
go Hayes! I'll never use anything else until someone begs me to try it out
avid v-brakes, Shimano lx v-brakes, shimano xt v-brakes
[Mar 26, 2007]
Andrew Payne
OVERALL
RATING
VALUE
RATING
Strength:
good stopping power just after being worn in
Weakness:
i go through pads ALOT. one day at whistler and i needed new pads 3 times, they blow chunks
go with juicy's or magura louis or gustus(the best i have ever ridden)
none older model hopes
[Sep 04, 2006]
TrailMaker
Weekend Warrior
OVERALL
RATING
4
VALUE
RATING
4
Strength:
Easy to find. Good price. They work.
Weakness:
None
The Hayes pads work. They stop well, last a long time, and are quiet - in dry, wet, mud - if you break them in right. They are a good product that does the job with no fuss. I have Delta Aztec pads on the front right now, and they HOWL like a wounded Moose when they are wet. Very annoying.
I'm going back to Hayes!
Delta Aztec
MTBR Newsletter
Get the latest mountain bike reviews, news, race results, and much more by signing up for the MTBR Newsletter
© Copyright 2024 VerticalScope Inc. All rights reserved.
